Java语言基础:内部类
发布时间:2011-3-27 00:51
发布者:1770309616
1. 普通内部类 •普通内部类的一个最简单的例子: view plaincopy to clipboardprint? // 外部类 class OutterClass { // 内部类 public class InnerClass { private int i = 0; public int getInt(){ return i; } } public void proc(){ InnerClass inClass = new InnerClass(); System.out.println(inClass.getInt()); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); outClass.proc(); } } // 外部类 class OutterClass { // 内部类 public class InnerClass { private int i = 0; public int getInt(){ return i; } } public void proc(){ InnerClass inClass = new InnerClass(); System.out.println(inClass.getInt()); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); outClass.proc(); } } •外部类可以访问内部类的私有成员,内部类也可以访问外部类的私有成员: view plaincopy to clipboardprint? // 外部类 class OutterClass { private int mOut = 10; // 内部类 public class InnerClass { private int mIn = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(mOut); } } public void printInPrivate(){ InnerClass inClass = new InnerClass(); // 直接打印内部类的私有成员 System.out.println(inClass.mIn); } public void printOutPrivate(){ InnerClass inClass = new InnerClass(); inClass.printOutPrivate(); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); outClass.printInPrivate(); outClass.printOutPrivate(); } } // 外部类 class OutterClass { private int mOut = 10; // 内部类 public class InnerClass { private int mIn = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(mOut); } } public void printInPrivate(){ InnerClass inClass = new InnerClass(); // 直接打印内部类的私有成员 System.out.println(inClass.mIn); } public void printOutPrivate(){ InnerClass inClass = new InnerClass(); inClass.printOutPrivate(); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); outClass.printInPrivate(); outClass.printOutPrivate(); } } •如果外部类的成员变量与内部类的成员变量名字相同,当内部类要访问外部类的该成员时,可以使用“OutClass.this.mem”来区分: view plaincopy to clipboardprint? // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } } // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } } •要创建普通内部类,必须先创建相应的外部类: view plaincopy to clipboardprint? // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); OutterClass.InnerClass inClass = outClass.new InnerClass(); inClass.printOutPrivate(); } } // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); OutterClass.InnerClass inClass = outClass.new InnerClass(); inClass.printOutPrivate(); } } 也可以用下面的方式: view plaincopy to clipboardprint? // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } public InnerClass newInnerClass() { return new InnerClass(); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); OutterClass.InnerClass inClass = outClass.newInnerClass(); inClass.printOutPrivate(); } } // 外部类 class OutterClass { private int mMem = 10; // 内部类 public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 直接打印外部类的成员 System.out.println(OutterClass.this.mMem); } } public InnerClass newInnerClass() { return new InnerClass(); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); OutterClass.InnerClass inClass = outClass.newInnerClass(); inClass.printOutPrivate(); } } 2. 静态内部类 普通内部类前面加上static修饰符,就成为静态内部类,静态内部类类似于C++的嵌套类,与普通内部类相比有如下区别: •静态内部类没有指向外部类的引用,外部类对于它来说更像一个名字空间。 •普通内部类不能有静态成员,静态方法,或另一个静态内部类;而静态内部类可以有这一切。 •静态内部类可以直接创建,不必先创建外部类: view plaincopy to clipboardprint? // 外部类 class OutterClass { private int mMem = 0; // 静态内部类 static public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 这是错误的 // System.out.println(OutterClass.this.mMem); } } public void printInPrivate() { InnerClass inClass = new InnerClass(); // 可以直接访问静态内部类的成员 System.out.println(inClass.mMem); } } public class Main { public static void main(String[] args) { // 直接创建静态内部类 OutterClass.InnerClass inClass = new OutterClass.InnerClass(); inClass.printOutPrivate(); } } // 外部类 class OutterClass { private int mMem = 0; // 静态内部类 static public class InnerClass { private int mMem = 0; public void printOutPrivate(){ // 这是错误的 // System.out.println(OutterClass.this.mMem); } } public void printInPrivate() { InnerClass inClass = new InnerClass(); // 可以直接访问静态内部类的成员 System.out.println(inClass.mMem); } } public class Main { public static void main(String[] args) { // 直接创建静态内部类 OutterClass.InnerClass inClass = new OutterClass.InnerClass(); inClass.printOutPrivate(); } } 从上面描述可以看出,静态内部类与一般类没有太大区别,只不过它是放在一个类的里面,这个类相当于它的名字空间,可以防止命名冲突。 3. 局部内部类 Java可以把一个类定义在一个方法里面,甚至是一个{}块里面,它的作用域就在这个块里面: view plaincopy to clipboardprint? // 外部类 class OutterClass { public void testLocalInner() { if (true) { class LocalInner { public void proc() { System.out.println("hello"); } } // 可以创建使用 LocalInner localInner = new LocalInner(); localInner.proc(); } // 错误:超出类定义的作用域 LocalInner localInner = new LocalInner(); localInner.proc(); } } // 外部类 class OutterClass { public void testLocalInner() { if (true) { class LocalInner { public void proc() { System.out.println("hello"); } } // 可以创建使用 LocalInner localInner = new LocalInner(); localInner.proc(); } // 错误:超出类定义的作用域 LocalInner localInner = new LocalInner(); localInner.proc(); } } 局部内部类的一般用途是实现某个接口,并作为这个接口传出方法被使用: view plaincopy to clipboardprint? // 接口 interface Talker { public void Talk(); } // 外部类 class OutterClass { public Talker getTalker() { // 现实该接口的局部内部类 class SomeTalker implements Talker { public void Talk() { System.out.println("hello"); } } // 创建类实例并作为Talker返回 SomeTalker talker = new SomeTalker(); return talker; } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); Talker talker = outClass.getTalker(); talker.Talk(); } } // 接口 interface Talker { public void Talk(); } // 外部类 class OutterClass { public Talker getTalker() { // 现实该接口的局部内部类 class SomeTalker implements Talker { public void Talk() { System.out.println("hello"); } } // 创建类实例并作为Talker返回 SomeTalker talker = new SomeTalker(); return talker; } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); Talker talker = outClass.getTalker(); talker.Talk(); } } 4. 匿名内部类 匿名内部类的语法如下: view plaincopy to clipboardprint? new InterfaceName(){......}; 或 new SuperclassName(){......}; new InterfaceName(){......}; 或 new SuperclassName(){......}; 它被认为是InterfaceName的实现者,或是SuperclassName的继承类,匿名内部类没有构建函数,如果SuperclassName有带参数的构造函数,必须在创建匿名内部类时带上这些参数,下面是匿名内部类最常见的使用场合: view plaincopy to clipboardprint? // 接口 interface Talker { public void Talk(); } // 外部类 class OutterClass { public void Talk(Talker talker) { talker.Talk(); } } public class Main { public static void main(String[] args) { OutterClass outClass = new OutterClass(); // 直接生成一个匿名内部类 outClass.Talk(new Talker(){ public void Talk() { System.out.println("hello"); } }); } } |
