龙芯2K1000搭载ES8396应用平板电脑替代ALC5651
发布时间:2020-7-14 14:08
发布者:soundbaraudio
龙芯2K1000处理器是面向网络安全领域及移动智能终端领域的双核处理器芯片。龙芯2K1000处理器集成两个GS264处理器核,芯片外围接口包括两路PCIE2.0、一路SATA2.0、4路USB2.0、两路DVO、64位DDR2/3及其它多种接口,可以满足中低端网络安全应用领域需求,并为其扩展应用提供相应接口。 提供样品 测试板 设计指南 151 1247 6010 莫先生,qq 238 396 0712 。 ES7134 ES7144 ES7145 ES7148 ES7149 ES7154 ES7210 ES7241 ES7242 ES7243 ES8156 ES8218 ES8311 ES8312 ES8316 ES8323S ES8374 ES8388 ES8396 ES7134 2-ch DAC SOP-8 Slave S 95 -85 3 to 3.6 ES7144 2-ch DAC TSSOP-10 Slave S 100 -85 3 to 3.6 ES7145 2-ch DAC TSSOP-10 Slave S 100 -85 3 to 5.5 ES7148 2-ch DAC 2.5x2.5 QFN-12 Slave S 100 -85 3 to 3.6 ES7149 2-ch DAC 2.5x2.5 QFN-12 Slave S 106 -85 Differential output 3 to 3.6 ES7154 2-ch DAC SOP-14 Slave S/USB/NS 102 -85 2Vrms 4 to 5.25 ES7210 4-ch ADC 4x4 QFN-32 Both S/USB/NS 102 -85 Up to 16-ch TDM/I2S 1.7 to 3.6 ES7241 2-ch ADC 3x3 QFN-16 Both S/USB/NS 100 -85 3 to 3.6 ES7242 2-ch ADC 4x4 QFN-24 Both S/USB/NS 100 -85 4:1 analog mux 3 to 3.6 ES7243E 2-ch ADC 3x3 QFN-20 Both S/USB/NS 102 -85 Up to 16-ch TDM/I2S 1.7 to 3.6 Low Power DAC, ADC, CODEC Series ES8156 2-ch DAC 3x3 QFN-20 Both S/USB/NS 110 -80 Yes Yes 7-band PEQ, DRC 1.6 to 3.6 ES8218 1-ch ADC 4x4 QFN-28 Both S/USB/NS 95 -85 1.6 to 3.6 ES8311 1-ch DAC 1-ch ADC 3x3 QFN-20 Both S/USB/NS DAC 110 ADC 100 DAC -80 ADC -93 Yes Yes Noise reduction filter DAC DRC 1.6 to 3.6 ES8312 1-ch DAC 1-ch ADC 4x4 QFN-28 Both S/USB/NS DAC 110 ADC 100 DAC -80 ADC -93 Yes Yes Noise reduction filter DAC DRC, FM in 1.6 to 3.6 ES8316 2-ch DAC 1-ch ADC 4x4 QFN-32 Both S/USB/NS DAC 96 ADC 95 DAC -83 ADC -85 Yes (ground centered) Yes 3-band PEQ 1.7 to 3.6 ES8323S 2-ch DAC 1-ch ADC 4x4 QFN-28 Both S/USB DAC 96 ADC 95 DAC -83 ADC -85 Yes Yes 1.7 to 3.6 ES8374 1-ch DAC 1-ch ADC 4x4 QFN-28 Both S/USB/NS DAC 96 ADC 95 DAC -83 ADC -85 Yes Class D Yes Yes Noise reduction filter 3 to 5.5 ES8388 2-ch DAC 2-ch ADC 4x4 QFN-28 Both S/USB DAC 96 ADC 95 DAC -83 ADC -85 Yes Yes 1.5 to 3.6 ES8396 2-ch DAC 2-ch ADC 6x6 QFN-48 Both S/USB/NS DAC 96 ADC 95 DAC -83 ADC -85 Yes (ground centered) Class D Yes Yes Dual I2S/PCM 6-band PEQ 1.7 to 3.6 |
