查看: 5815|回复: 0
GAL16V8反汇编源程序(原创)
发表于 2009-4-2 23:14:51 | 显示全部楼层 |阅读模式
关键词: 程序 , 汇编 , 原创
//菜农HotPower@126.com  2003.8.21 于雁塔菜地//GAL16V8反汇编源程序JED2ABEL.C
#include
#include
#include
#include
#include
#include
#include
#include
unsigned int getfusessum(unsigned char *str);
unsigned int getfusessum(unsigned char *str){
unsigned char ch;
unsigned int fusessum=0;
unsigned int i,j;
    for(i=0;i<275;i++){
       ch=0;
       for(j=0;j<8;j++){
          ch>>=1;
          if(*str++=='1') ch|=0x80;
       fusessum+=ch;
    return fusessum;
unsigned char getstrhex(unsigned char *str);
unsigned char ch=0;
unsigned int i;
    for(i=0;i<8;i++){
       ch<<=1;
       if(*str++=='1') ch++;
    return ch;
main(int argc,char *argv[])
FILE *fp1,*fp2,*fp3;
unsigned int  x,y,z,i,j,k;
unsigned char *filename1,*filename2,*str,*ptr,*ctr,ch,ck;
unsigned char *p1=".jed",*p2=".pld";
unsigned long pccount,address=0,addressx=0;
unsigned char STX=0x02,ETX=0x03;
unsigned int SYN=2192,AC0=2193,XORN=2120;
unsigned char *buffer="Jed2Abel Version 3.01 Copyright (c) 1993,2008 HotPower";
unsigned char fuses[2200];
unsigned char outpins[]={2,1,3,19,4,18,5,17,6,14,7,13,8,12,9,11};//P16V8S
unsigned char outpinc[]={2,1,3,18,4,17,5,16,6,15,7,14,8,13,9,11};//P16V8C
unsigned char outpinr[]={2,19,3,18,4,17,5,16,6,15,7,14,8,13,9,12};//P16V8R
unsigned char *pinname[]={
              "P01     ",
              "P02     ",
              "P03     ",
              "P04     ",
              "P05     ",
              "P06     ",
              "P07     ",
              "P08     ",
              "P09     ",
              "GND     ",
              "P11     ",
              "P12     ",
              "P13     ",
              "P14     ",
              "P15     ",
              "P16     ",
              "P17     ",
              "P18     ",
              "P19     ",
              "VCC     "};
unsigned char *outpin;
unsigned int crc0=0,crc1=0;
unsigned int crcs0=0,crcs1=0;
unsigned int fusesum=0;
unsigned int pin;
    puts(buffer);
    if (argc<2 || argc>3) {
       puts("Syntax: Jed2Abel Jedfilename[.JED] [Abelfilename][.PLD]");
       exit(1);
    filename1=(unsigned char*)calloc(64,sizeof(char));
    filename2=(unsigned char*)calloc(64,sizeof(char));
    str=argv[1];
    ptr=(argc==3) ? argv[2] : filename2;
    strcpy(filename1,str);
    strcpy(filename2,ptr);
    str=filename1;
    ptr=filename2;
    strlwr(str);
    strlwr(ptr);
    if(islower(*str)) *str^=0x20;
    if(islower(*str)) *ptr^=0x20;
    while (*str && (*str!='.')) str++;
    if (*str!='.') strcat(filename1,p1);
    if ((fp1=fopen(filename1,"rb+"))==NULL) {
       printf("Not found Jedfile:[");
       printf(filename1);
       puts("]");
       free(filename1);
       free(filename2);
       exit(1);
    while(!feof(fp1) && (ch=fgetc(fp1))!=STX);
    if(ch!=STX){
       free(filename1);
       free(filename2);
       exit(1);
    crc0=ch;
    while(!feof(fp1) && (ch=fgetc(fp1))!=ETX) crc0+=ch;
    crc0+=ch;
    if(ch==ETX){
       address=ftell(fp1);
       fscanf(fp1,"%04X",&crcs0);
    if(crc0!=crcs0){//CRC出错
       printf("MoveData_CRC Error!!!\r\n");
       if(ch==ETX){
          printf("OverWrite(Y/N)\n");
          ch=getch();
          printf("\r\n");
          if(ch=='Y' || ch=='y'){
         fseek(fp1,address,SEEK_SET);
         fprintf(fp1,"%04X",crc0);//强行改写CRC错误!
          else{
         free(filename1);
         free(filename2);
         exit(1);
       else{
          ch=getch();
          printf("\r\n");
          else{
         free(filename1);
         free(filename2);
         exit(1);
    rewind(fp1);
    while(!feof(fp1)){
       while(!feof(fp1) && fgetc(fp1)!='Q');
       if(!feof(fp1) && fgetc(fp1)=='F'){
          fscanf(fp1,"%04d",&fusesum);//QF2194
          break;
    if(feof(fp1) || fgetc(fp1)!='*' || fusesum!=2194){
       printf("No GAL16V8 JedFile!!!\n");
       ch=getch();
       printf("\r\n");
         rewind(fp1);
         fusesum=2194;//强行反汇编
       else{
         free(filename1);
         free(filename2);
         exit(1);
    str=fuses;
    for(i=0;i<2200;i++) *str++='0';
    ck=0;
    while(!feof(fp1)){
       ch=fgetc(fp1);
       if(ch=='L' && ck==0x0a) break;
       ck=ch;
    while(ch=='L'){
       address=ftell(fp1);
       pccount=0;
       while(!feof(fp1) && (ch=fgetc(fp1))>='0' && ch<='9'){
          pccount*=10;
          pccount+=ch&0x0f;
       str=fuses+pccount;
       while(ch!='*'){
          if(ch=='1' || ch=='0'){
         *str++=ch;
         pccount++;
          ch=fgetc(fp1);
       addressx=ftell(fp1);
       while(!feof(fp1) && (ch=fgetc(fp1))!='L' && ch!='C' && ch!='V');
    while(!feof(fp1) && ch=='V'){
        while(!feof(fp1) && (ch=fgetc(fp1))!='*' && (ch=fgetc(fp1))!='\n');
        ch=fgetc(fp1);
    while(!feof(fp1) && ch!='C') ch=fgetc(fp1);
    if(ch=='C'){
        address=ftell(fp1);
        fscanf(fp1,"%04X",&crcs1);
    str=fuses;
    crc1=getfusessum(str);
    if(crc1!=crcs1){
       printf("FusesData_CRC Error!!!\n");
       if(ch=='C'){
          ch=getch();
          printf("\r\n");
         fprintf(fp1,"%04X",crc1);
          else{
         free(filename1);
         free(filename2);
         exit(1);
    if (argc==2) {
       str=filename1;
       while (*str!='.') *ptr++=*str++;
       *ptr=0;
       strcat(filename2,p2);
       else {
          while (*ptr && (*ptr!='.')) ptr++;
          if (*ptr==0) strcat(filename2,p2);
          else {
         ptr++;
         printf("Jed2Abel Abelfile:[");
         printf(filename2);
         printf("] (Y/N)?");
         ch=getch();
         printf("\r\n");
         if (ch=='Y' || ch=='y') {
            printf("Jed2Abel Convert (Y/N)?");
            ch=getch();
            printf("\r\n");
            if ((ch&=0x0df) !='Y') {
               fclose(fp1);
               free(filename1);
               free(filename2);
               exit(1);
         else {
            fclose(fp1);
            free(filename1);
            free(filename2);
            exit(1);
    if (_chmod(filename2,1,0x20)==0x20) {
       printf("Overwrite existing Abelfile:[");
       printf(filename2);
       printf("] (Y/N)?");
       ch=getch();
       printf("\r\n");
       if ((ch&0x0df)!='Y') {
          fclose(fp1);
          free(filename1);
          free(filename2);
          exit(1);
    if ((fp2=fopen(filename2,"wt"))==NULL) {
       printf("Not open Abelfile:[");
       printf(filename2);
       puts("]");
       fclose(fp1);
       free(filename1);
       free(filename2);
       exit(1);
    for(pin=0;pin<20;pin++){
       ctr=pinname[pin];
       while(*ctr && *ctr!=' ') ctr++;
       *ctr=0;
    ptr=filename2;
    while(*ptr&&*ptr!='.') ptr++;
    ctr=ptr;
    *ctr++='.';//用户定义管脚文件默认"*.PIN"
    *ctr++='P';
    *ctr++='i';
    *ctr++='n';
    *ctr=0;
    if ((fp3=fopen(filename2,"rt"))!=NULL){//用户定义管脚文件"pldfilename.pin"
       while(!feof(fp3)){
          while(!feof(fp3) && (ch=fgetc(fp3))!='P');//只认大写字母P
          pin=0;
          while(!feof(fp3) && (ch=fgetc(fp3))>='0' && ch<='9'){//只认数字管脚号
         pin*=10;
         pin+=ch&0x0f;
          if(ch=='=' && pin>0 && pin<20){//P1=....P20=...
         ctr=buffer;
         while(!feof(fp3) && (ch=fgetc(fp3))!=';'){//每个管脚定义以分号;结尾
            *ctr++=ch;
         *ctr=0;
         *(ctr+8)=0;
         if(ch==';'){
            ctr=buffer;
            strcpy(pinname[pin-1],ctr);//管脚定义名称  P2=ABC;...P13=OUT;...
       fclose(fp3);
    else{
       if(fuses[SYN]=='0' && fuses[AC0]=='1'){
          strcpy(pinname[0],"Clk");
          strcpy(pinname[10],"OE");
    *ptr=0;
    ptr=filename2;
    str=filename1;
    while(*str&&*str!='.') str++;
    *str=0;
    str=filename1;
    printf("Jed2Abel ");
    printf(filename1);
    printf(" To ");
    puts(filename2);
    printf("Jed2Abel ConVert start, Please Wait...\r\n\r\n");
    rewind(fp2);
    fprintf(fp2,"module _%s\n",str);
    fprintf(fp2,"\ntitle 'Jed2Abel Version 3.01 Copyright (c) 1993,2008\n");
    fprintf(fp2,"       Jed2Abel JedFile:[%s.Jed]\n",str);
    fprintf(fp2,"       HotPower  1992.11.19'\n\n");
//fuses[SYN]=='0' && fuses[AC0]=='1' P16V8R
//fuses[SYN]=='1' && fuses[AC0]=='1' P16V8C
//fuses[SYN]=='1' && fuses[AC0]=='0' P16V8S
    if(fuses[SYN]=='1' && fuses[AC0]=='0'){
       fprintf(fp2,"       %s device 'P16V8S';\"Make JedFusesFile %s.Jed\n",ptr,ptr);
       printf(" %s.Jed device 'P16V8S';\n",ptr);
       outpin=outpins;
    else{
       if(fuses[SYN]=='1' && fuses[AC0]=='1'){
          fprintf(fp2,"       %s device 'P16V8C';\"Make JedFusesFile %s.Jed\n",ptr,ptr);
          printf("%s.Jed device 'P16V8C';\n",ptr);
          outpin=outpinc;
       else{
         fprintf(fp2,"       %s device 'P16V8R';\"Make JedFusesFile %s.Jed\n",ptr,ptr);
         printf("%s.Jed device 'P16V8R';\n",ptr);
         outpin=outpinr;
    fprintf(fp2,"\n");
    for(pin=0;pin<9;pin++){
        if(pin) fprintf(fp2,",");
        fprintf(fp2,"%s",pinname[pin]);
    fprintf(fp2," Pin ");
    for(pin=1;pin<10;pin++){
        if(pin>1) fprintf(fp2,",");
        fprintf(fp2,"%1d",pin);
    fprintf(fp2,";\n");
    for(pin=10;pin<19;pin++){
        if(pin>10) fprintf(fp2,",");
    for(pin=11;pin<20;pin++){
        if(pin>11) fprintf(fp2,",");
        fprintf(fp2,"%2d",pin);
    fprintf(fp2,";\n\n");
    y=0;
    for(x=0,pin=19;pin>=12;x++,pin--){
       if(fuses[SYN]=='0' && fuses[XORN+x]=='0') y++;
    if(y){
       for(x=0,pin=18;pin>=11;x++,pin--){
          if(fuses[SYN]=='0' && fuses[XORN+x]=='0'){
         if(--y) fprintf(fp2,",");
       fprintf(fp2," istype 'reg,pin';\n");
    y=0;
       if(!(fuses[SYN]=='0' && fuses[XORN+x]=='0')) y++;
    if(y){
          if(!(fuses[SYN]=='0' && fuses[XORN+x]=='0')){
       fprintf(fp2," istype 'com';\n");
    y=0;
//fuses[2048..2055]=1 pos;
//fuses[2048..2055]=0 neg;
       if(fuses[2048+x]=='1') y++;
    if(y){
          if(fuses[2048+x]=='1'){
       fprintf(fp2," istype 'pos';\n");
    y=0;
       if(fuses[2048+x]=='0') y++;
    if(y){
          if(fuses[2048+x]=='0'){
       fprintf(fp2," istype 'neg';\n");
    y=0;
       if(fuses[AC0]=='1' && fuses[XORN+x]=='1') y++;
    if(y){
          if(fuses[AC0]=='1' && fuses[XORN+x]=='1'){
       fprintf(fp2," istype 'eqn';\n");
    fprintf(fp2,"\nH,L,X,Z,C,P=1,0,.X.,.Z.,.C.,.P.;\n");
    fprintf(fp2,"\nequations\n");
       str=fuses+x*32*8;
       ptr=str;
       y=0;
       z=0;
       k=0;
       for(i=0;i<32*8;i++){
          if(*ptr++=='0') y++;
          else z++;
       if(z){
          for(i=0;i<8;i++){
         ptr=str+i*32;
         y=0;
         z=0;
         for(j=0;j<32;j++){
            else z++;
         if(k==0){
            if(fuses[2048+x]=='0' && !(i==0 && fuses[AC0]=='1' && fuses[XORN+x]=='1')) fprintf(fp2,"!");
            else fprintf(fp2," ");
         if(i==0){
               fprintf(fp2,".oe =");
            else k++;
         else k++;
         if(k==1){
            if(fuses[SYN]=='0' && fuses[XORN+x]=='0') fprintf(fp2," :=");
            else fprintf(fp2," =");
         if(y==0){
            if(k==0){
               fprintf(fp2," 1;\n");
         else{
            if(z==0){
               if(k==0){
              fprintf(fp2," 0;\n");
            else{
               if(k>1) fprintf(fp2,"\n     #");
               ptr=fuses+x*32*8;
               ptr+=i*32;
               z=0;
               for(j=0;j<32;j++){
              if(*ptr=='0'){
                 if(z) fprintf(fp2," &");
                 if(j&0x01) fprintf(fp2," !");
                 y=j>>1;
                 fprintf(fp2,"%s",pinname[*(outpin+y)-1]);
                 z++;
              ptr++;
               if(k==0) fprintf(fp2,";\n");
          if(k>1) fprintf(fp2,";\n");
       else{
          fprintf(fp2,"\"%s =Input Pin\n",pinname[pin]);
    fprintf(fp2,"\nfuses \n");
    str=fuses;
    ch=getstrhex(str+2056);
//fuses[2056..2063] string
    fprintf(fp2," [2056..2063]=");
    if(ch==0) fprintf(fp2,"'';\n");
    else{
       if(ch>=' ') fprintf(fp2,"'%c';\n",ch);
       else fprintf(fp2,"^h%02X;\n",ch);
    ch=getstrhex(str+2064);
    fprintf(fp2," [2064..2071]=");
    else{
    ch=getstrhex(str+2072);
    fprintf(fp2," [2072..2079]=");
    else{
    ch=getstrhex(str+2080);
    fprintf(fp2," [2080..2087]=");
    else{
    ch=getstrhex(str+2088);
    fprintf(fp2," [2088..2095]=");
    else{
    ch=getstrhex(str+2096);
    fprintf(fp2," [2096..2103]=");
    else{
    ch=getstrhex(str+2104);
    fprintf(fp2," [2104..2111]=");
    else{
    ch=getstrhex(str+2112);
    fprintf(fp2," [2112..2119]=");
    else{
    fseek(fp1,addressx,SEEK_SET);
    while(!feof(fp1) && (ch=fgetc(fp1))!='V');
    y=1;
    *(buffer+20)=0;
        fscanf(fp1,"%04d",&pccount);
        while(!feof(fp1) && (ch=fgetc(fp1))!=' ');
        fprintf(fp2,"\ntest_vectors\"V%04d\n",y++);
        fscanf(fp1,"%20c",buffer);
        str=buffer;
        fprintf(fp2,"([");
        z=0;
        for(pin=0;pin<19;pin++){
           if(*str=='0' || *str=='1' || *str=='C' || *str=='P'){
          if(z) fprintf(fp2,",");
          fprintf(fp2,"%s",pinname][pin]);
          z++;
           str++;
        fprintf(fp2,"]->[");
        str=buffer;
        z=0;
           if(*str=='H' || *str=='L' || *str=='Z'){
          z++;
           str++;
        fprintf(fp2,"])\n");
        str=buffer;
        fprintf(fp2," [");
        z=0;
        for(pin=1;pin<=19;pin++){
          if(*str=='0') fprintf(fp2," L ");
          else{
             if(*str=='1') fprintf(fp2," H ");
             else fprintf(fp2," %c ",*str);
          z++;
           str++;
        str=buffer;
        z=0;
          z++;
           str++;
        fprintf(fp2,"];\n");
    str=filename1;
    *str=0;
    str=filename1;
    fprintf(fp2,"\nend _%s\n",str);
    free(filename1);
    free(filename2);
    fclose(fp1);
