AD7798BRUZ-REEL的参数特点
发布时间:2019-5-5 15:05
发布者:xunavc
位数:16 采样率(每秒):470 输入数:3 输入类型:差分 数据接口:SPI,DSP 配置:MUX-ADC 无线电 - S/H:ADC:- A/D 转换器数:1 架构:三角积分 参考类型:外部 电压 - 电源,模拟:2.7V ~ 5.25V 电压 - 电源,数字:2.7V ~ 5.25V 特性:- 工作温度:-40°C ~ 105°C 封装/外壳:16-TSSOP(0.173",4.40mm 宽) 供应商器件封装:16-TSSOP 安装类型:表面贴装 Manufacturer: Analog Devices Inc. Product Category: Analog to Digital Converters - ADCRoHS: DetailsSeries: AD7798Mounting Style: SMD/SMT Package / Case: TSSOP-16 Resolution: 16 bit Number of Channels: 3 Channel Sampling Rate: 470 S/s Input Type: Differential Interface Type: 3-Wire, SPI Architecture: Sigma-Delta Reference Type: External Minimum Operating Temperature: - 40 C Maximum Operating Temperature: + 105 C Packaging: Reel Height: 1.05 mm Input Voltage: +/- 2.5 V Length: 5 mm Number of Converters: 1 Converter Width: 4.4 mm Brand: Analog Devices Gain Error: +/- 10 uV INL - Integral Nonlinearity: +/- 15 ppm of FSRNumber of ADC Inputs: 3 InputOperating Supply Voltage: 5 VPd - Power Dissipation: 2 mW Product Type: ADCs - Analog to Digital ConvertersSample and Hold: NoFactory Pack Quantity: 2500Subcategory: Data Converter ICs Unit Weight: 173 mg 以上就是AD7798BRUZ-REEL www.dzsc.com/ic-detail/9_8723.html的参数特点 RoHS: 详细信息 系列: AD7798 安装风格: SMD/SMT 封装 / 箱体: TSSOP-16 分辨率: 16 bit 通道数量: 3 Channel 采样比: 470 S/s 输入类型: Differential 接口类型: 3-Wire, SPI 结构: Sigma-Delta 参考类型: External 最小工作温度: - 40 C 最大工作温度: + 105 C 封装: Reel 高度: 1.05 mm 输入电压: +/- 2.5 V 长度: 5 mm 转换器数量: 1 Converter 宽度: 4.4 mm 商标: Analog Devices 增益误差: +/- 10 uV INL - 积分非线性: +/- 15 ppm of FSR ADC 输入端数量: 3 Input 工作电源电压: 5 V Pd-功率耗散: 2 mW 产品类型: ADCs - Analog to Digital Converters采样和保持: No 工厂包装数量: 2500 子类别: Data Converter ICs 单位重量: 173 mg |
