POR资料:CIRCUIT DESIGN OF THE POWER-ON RESET
发布时间:2010-11-10 19:53
发布者:看门狗
POR
ABSTRACT: The Power-ON reset, which is described here, is a part of the electronics of the Atlas Liquid Argon Calorimeter calibration circuit. A Power-ON Reset is a power supply supervisor which allows to generate a reset signal after a power supply level detection. Integrated with a digital circuit on the same wafer, it avoids the use of a discrete component. The reset time range is 1 microsecond to 1 second. It is controlled using two external discrete components. |
