查看: 4600|回复: 3
来个宏定义玩玩,呵呵~
发表于 2009-7-14 16:38:37 | 显示全部楼层 |阅读模式
关键词: 定义
从驱动接口宏定义抽出来
第一个数据结构
// Driver functions:驱动函数
CYG_ADC_FUNCTIONS( lpc2xxx_adc_funs,
                   lpc2xxx_adc_enable,
                   lpc2xxx_adc_disable,
                   lpc2xxx_adc_set_rate );
//doc中的解释说明
The macro CYG_ADC_FUNCTIONS() instantiates a function table called example_adc_funs and populates it with the ADC driver functions
//宏定义原型
#define CYG_ADC_FUNCTIONS( __name, __enable, __disable, __set_rate )    \
cyg_adc_functions __name =                                              \
    .enable               = __enable,                                          \
    .disable              = __disable,                                          \
    .set_rate            = __set_rate                                         \
//adc函数定义原型,一个结构体包含了三个函数指针
struct cyg_adc_functions
    void (*enable)( cyg_adc_channel *chan );
    void (*disable)( cyg_adc_channel *chan );
    void (*set_rate)( cyg_adc_channel *chan, cyg_uint32 rate );
宏展开的结果:定义了一个cyg_adc_funtions包含了函数指针的结构体
cyg_adc_functions  lpc2xxx_adc_funs{
    .enable               =  lpc2xxx_adc_enable,
    .disable              =  lpc2xxx_adc_disable,
    .set_rate            =  lpc2xxx_adc_set_rate
//ADC信息的私有数据
static lpc2xxx_adc_info lpc2xxx_adc_info0 =
    .base               = CYGARC_HAL_LPC2XXX_REG_AD_BASE,
    .vector             = CYGNUM_HAL_INTERRUPT_TIMER1,
    .intprio            = CYGNUM_DEVS_ADC_ARM_LPC24XX_INTPRIO,
    .int_handle         = 0,
#if CYGPKG_DEVS_ADC_ARM_LPC24XX_DEBUG_LEVEL > 0
    .isr_cnt            = 0,
#endif
    .chan_mask          = 0
//ADC驱动的总结构,包含了上述的两部分驱动函数和私有数据
CYG_ADC_DEVICE( lpc2xxx_adc_device,               //名字
                &lpc2xxx_adc_funs,                                 //驱动函数
                &lpc2xxx_adc_info0,                                //驱动信息私有数据
                CYGNUM_DEVS_ADC_ARM_LPC24XX_DEFAULT_RATE);    //默认采样率
宏定义
#define CYG_ADC_DEVICE(__name, __funs, __dev_priv, __rate )     \
cyg_adc_device __name =                                         \
    .funs                    = __funs,                               \
    .dev_priv             = __dev_priv,                           \
    .config.rate         = __rate,                               \
    .init               = false                                 \
展开宏定义的结果
cyg_adc_device lpc2xxx_adc_device =                                             \
    .funs                   = lpc2xxx_adc_funs, ,                                            \
    .dev_priv            = lpc2xxx_adc_info0,
    .config.rate          =CYGNUM_DEVS_ADC_ARM_LPC24XX_DEFAULT_RATE,
    .init                      = false
//ADC0~7驱动的注册
LPC2XXX_ADC_CHANNEL(0~7)
//原型
#define LPC2XXX_ADC_CHANNEL( __chan )                                    \
CYG_ADC_CHANNEL( lpc2xxx_adc_channel##__chan,                            \
                 __chan,                                                 \
                 CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL##__chan##_BUFSIZE,  \
                 &lpc2xxx_adc_device );                                  \
DEVTAB_ENTRY( lpc2xxx_adc_channel##__chan##_device,                      \
              CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL##__chan##_NAME,        \
              0,                                                         \
              &cyg_io_adc_devio,                                         \
              lpc2xxx_adc_init,                                          \
              lpc2xxx_adc_lookup,                                        \
              &lpc2xxx_adc_channel##__chan );
(1)第一步展开,将"##__chan"和"##_chan##"替换为__chan的数值,假设为0
CYG_ADC_CHANNEL( lpc2xxx_adc_channel0,                                        \
                 0,        \
                 CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_BUFSIZE,  \
DEVTAB_ENTRY( lpc2xxx_adc_channel0_device,                                 \
              CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_NAME,        \
              0,        \
              lpc2xxx_adc_init,        \
              &lpc2xxx_adc_channel0 );
//CYG_ADC_CHANNEL宏定义原型
#define CYG_ADC_CHANNEL( __name, __channel, __bufsize, __device )
static cyg_adc_sample_t __name##_buf[__bufsize];
cyg_adc_channel __name =
    .channel            = __channel,                                    \
    .buf                = __name##_buf,                                 \
    .len                = __bufsize,                                    \
    .put                = 0,                                            \
    .get                = 0,                                            \
    .device             = __device,                                     \
    .init               = false                                         \
(2-1)CYG_ADC_CHANNLE再次展开后的结果:
static cyg_adc_sample_t lpc2xxx_adc_channel0_buf[CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_BUFSIZE];                        \
cyg_adc_channel lpc2xxx_adc_channel0 =        \
    .channel            = 0,        \
    .buf                    = lpc2xxx_adc_channel0_buf,                                                           \
    .len                    = CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_BUFSIZE,       \
    .put                   = 0,        \
    .get                   = 0,        \
    .device              = &lpc2xxx_adc_device,                                                           \
    .init                    = false        \
(2-2)DEVTAB_ENTRY宏定义的原型
    #define DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv) \
                   CHAR_DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv)
    #define CHAR_DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv)
       cyg_devtab_entry_t _l CYG_HAL_TABLE_ENTRY(devtab) = {
       _name,
       _dep_name,
       _handlers,
       _init,
       _lookup,
       _priv,
       CYG_DEVTAB_STATUS_CHAR
        展开结果
       0,
       lpc2xxx_adc_init,
       lpc2xxx_adc_lookup,
       &lpc2xxx_adc_channel0,
      CYG_HAL_TABLE_ENTRY()原型
    #define CYG_HAL_TABLE_ENTRY( _name ) \
                CYGBLD_ATTRIB_SECTION(".ecos.table." __xstring(_name) ".data")
            CYGBLD_ATTRIB_USED
      展开结果
                CYGBLD_ATTRIB_SECTION(".ecos.table.devtab.data")
            CYGBLD_ATTRIB_USED
      CYGBLD_ATTRIB_SECTION原型
        #define CYGBLD_ATTRIB_SECTION(__sect__) __attribute__((section (__sect__)))
      展开结果
       __attribute__((section (".ecos.table.devtab.data")))
       展开CYGBLD_ATTRIB_USED
    __attribute__((used))
    CYG_HAL_TABLE_ENTRY()的展开结果为
    DEVTAB_ENTRY的展开结果为
          cyg_devtab_entry_t _l  __attribute__((section (".ecos.table.devtab.data"))) __attribute__((used)) = {
           0,
           lpc2xxx_adc_init,
           lpc2xxx_adc_lookup,
总结LPC2XXX_ADC_CHANNEL(0)的宏定义结果为
    .channel            = 0,
    .put                   = 0,
    .get                   = 0,
    .init                    = false
           0,
           lpc2xxx_adc_init,
           lpc2xxx_adc_lookup,
因为公社的版本太窄了,导致很多行都乱了,所以把一些还行符删掉了~
看人家老外做的程序,专业~看不懂~
我要是分析的不对的,大家指正
 楼主| 发表于 2009-7-14 16:44:58 | 显示全部楼层
自己沙发,消灭0回复
 楼主| 发表于 2009-7-16 09:39:13 | 显示全部楼层
果然是没人看
发表于 2009-8-25 13:24:48 | 显示全部楼层
看不懂,为何要加个点(.enable)
