【教程】Android开发之dialog,activity 屏蔽Home键详解
发布时间:2013-8-23 16:01
发布者:
reggae
相信在Android应用上,很多时候逻辑是需要屏蔽Home键的,但这个用户体验是否需要,就看各位的需求了。
一般的方法屏蔽Home键,大家一定看过不少文章了。我总结一下,先说一下一般情况下Activity的屏蔽按键和Home键吧。
屏蔽其他键,重写onKeyDown
Java代码
- @Override
- public boolean onKeyDown(int keyCode, KeyEvent event) {
- Log.i(TAG,"keycode="+keyCode + " isBan="+isBan);
- switch (keyCode) {
- case KeyEvent.KEYCODE_BACK:
- Log.i(TAG,"KEYCODE_BACK");
- return true;
- return super.onKeyDown(keyCode, event);
复制代码
大家会发现,这里屏蔽Home键是捕捉不到的,因为大家的权限一般是User所以是无效的。
而其实android处理Home键等系统级按键是有一定的处理的。
引用 看看源码是怎样处理的 \frameworks\policies\base\phone\com\android\internal\policy\impl\PhoneWindowManager.java #1092 Java代码
- // First we always handle the home key here, so applications
- // can never break it, although if keyguard is on, we do let
- // it handle it, because that gives us the correct 5 second
- // timeout.
- if (code == KeyEvent.KEYCODE_HOME) {
- // If a system window has focus, then it doesn't make sense
- // right now to interact with applications.
- WindowManager.LayoutParams attrs = win != null ? win.getAttrs() : null;
- if (attrs != null) {
- final int type = attrs.type;
- if (type == WindowManager.LayoutParams.TYPE_KEYGUARD
- type == WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG) {
- // the "app" is keyguard, so give it the key
- return false;
- final int typeCount = WINDOW_TYPES_WHERE_HOME_DOESNT_WORK.length;
- for (int i=0; i
- if (type == WINDOW_TYPES_WHERE_HOME_DOESNT_WORK[i]) {
- // don't do anything, but also don't pass it to the app
- return true;
复制代码
通过源码,我们不难发现两个的参数 WindowManager.LayoutParams.TYPE_KEYGUARD和
借鉴于此,重写onAttachedToWindow,以实现屏蔽Home键 Java代码
- public void onAttachedToWindow() {
- this.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD);
- super.onAttachedToWindow();
复制代码
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 华丽的分界线,以下内容更精彩- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
轮到dialog了,如果在Activity弹出dialog,在Activity设置以上2个方法是没办法屏蔽的。
其实,原理是一样的,只是地方不一样而已。
Java代码
- final Dialog dialog = new Dialog(this);
- dialog.setContentView(R.layout.mydailog);
- dialog.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD);
- dialog.show();
- dialog.setOnKeyListener(new android.content.DialogInterface.OnKeyListener(){
- @Override
- public boolean onKey(DialogInterface dialog, int keyCode,KeyEvent event) {
- return true;
- return false;
复制代码
这样运行后,出错如下:
Error代码
- 10-18 13:27:06.380: ERROR/AndroidRuntime(4684): Caused by: android.view.WindowManager$BadTokenException: Unable to add window android.view.ViewRoot$W@2b046d68 -- permission denied for this window type
复制代码
其实,只需要把dialog.getWindow().setType的位置放在show后面就可以了
正确代码
- dialog.show();
复制代码
这么,就完成了Back键的屏蔽 和Home键盘的屏蔽了!
总结:
1在以上用WindowManager.LayoutParams.TYPE_KEYGUARD的地方改用
WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG 效果一样。至于两者的具体差别,得以后再研究研究。
2其实,在源码里是这样调用的。 Java代码
- final AlertDialog dialog = new AlertDialog.Builder(mContext)
- .setTitle(null)
- .setMessage(message)
- .setNeutralButton(R.string.ok, null)
- .create();
- dialog.getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD_DIALOG);
- dialog.show();
复制代码
但我们如果这样调用就会出现之前的那个error:permission denied for this window type 这就显而易见了吧~~
3ProgressDialog 默认屏蔽 Back键,Dialog,AlertDialog则需setOnKeyListener
4其实屏蔽Home键,在页面的某个地方,例如一个Button的onClick里,去设置setType就可以了,如:
Java代码
- button.setOnClickListener(new View.OnClickListener() {
- @Override
- public void onClick(View v) {
- getWindow().setType(WindowManager.LayoutParams.TYPE_KEYGUARD);
复制代码
但前提是重载Activity的onAttachedToWindow(),哪怕只是一个空实现,然后返回父类方法。
Java代码
- @Override
复制代码
5其实它们,都是常用的~ Java代码
- case KeyEvent.KEYCODE_HOME:
- Log.i(TAG,"KEYCODE_HOME");
- return true;
- return true;
- case KeyEvent.KEYCODE_CALL:
- Log.i(TAG,"KEYCODE_CALL");
- return true;
- case KeyEvent.KEYCODE_SYM:
- Log.i(TAG,"KEYCODE_SYM");
- return true;
- case KeyEvent.KEYCODE_VOLUME_DOWN:
- Log.i(TAG,"KEYCODE_VOLUME_DOWN");
- return true;
- case KeyEvent.KEYCODE_VOLUME_UP:
- Log.i(TAG,"KEYCODE_VOLUME_UP");
- return true;
- case KeyEvent.KEYCODE_STAR:
- Log.i(TAG,"KEYCODE_STAR");
- return true;
复制代码
希望大家看到这个文章能觉得有用,谢谢已阅者。更多安卓技术问题欢迎加群探讨:278744577,验证码:eec,不写验证不予通过哟~
