OnSemi NCP1271 通用AC-DC适配器设计方案
发布时间:2012-11-12 11:58
发布者:1770309616
OnSemi公司的NCP1271是一款最新的固定频率电流模式PWM开关控制器,具有为低级声频噪声提供可调节的Soft-Skip待机操作模式,为节省待机功耗内部集成高压启动,过载故障检测定时器,内部锁保护功能特性。本文首先介绍NCP1271、基本特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。 The NCP1271 represents a new, pin to pin compatible, generation of the successful 7−pin current mode NCP12XX product series. The controller allows for excellent stand by power consumption by use of its adjustable Soft−Skip mode and integrated high voltage startup FET. This proprietary Soft−Skip also dramatically reduces the risk of acoustic noise. This allows the use of inexpensive transformers and capacitors in the clamping network. Internal frequency jittering,ramp compensation, timer−based fault detection and a latch input make this controller an excellent candidate for converters where ruggedness and component cost are the key constraints. NCP1271主要特性: • Fixed−Frequency Current−Mode Operation with Ramp Compensation and Skip Cycle in Standby Condition • Timer−Based Fault Protection for Improved Overload Detection • “Soft−Skip Mode” Technique for Optimal Noise Control in Standby • Internal High−Voltage Startup Current Source for Lossless Startup • _5% Current Limit Accuracy over the Full Temperature Range • Adjustable Skip Level • Internal Latch for Easy Implementation of Overvoltage and Overtemperature Protection • Frequency Jittering for Softened EMI Signature • +500 mA/−800 mA Peak Current Drive Capability • Sub−100 mW Standby Power can be Achieved • Pin−to−in Compatible with the Existing NCP120X Series • This is a Pb−Free Device NCP1271应用领域: • AC−DC Adapters for Notebooks, LCD Monitors • Offline Battery Chargers • Consumer Electronic Appliances STB, DVD, DVDR 图1. NCP1271内部方框图 NCP1271ADAPGEVB方案介绍: This evaluation board user’s manual presents an example circuit using the NCP1271 (65 kHz version) in a flyback topology. The design steps and subsequent measurements are also included. An Excel based design worksheet is available at www.onsemi.com. The measurements show that the 19 V, 3.0 A circuit delivers above 85% across a universal input (85 to 265 Vac).The no load standby consumption is 83 mW at 230 Vac and the light load operation is greater than 75% efficient. NCP1271ADAPGEVB方案原理图: 图2. NCP1271ADAPGEVB方案原理图 NCP1271ADAPGEVB方案材料清单: PCB元件布局图: Top View Bottom View 详细资料如下 来源:网络 |
