ST STEVAL-ISV001V1 1kW逆变器解决方案
发布时间:2012-8-14 10:45    发布者:1770309616
关键词: ST , STEVAL-ISV001V1 , 逆变器
ST公司的STEVAL-ISV001V1评估板是采用STP160N75F3的1kW逆变器(DC/AC转换器),DC输入电压从表面上20V到28V,输出电压230Vrms 59Hz,输出功率达1000W,效率高达90%,主要用在UPS和光伏(PV)系统.本文介绍了DC/AC转换器系统框图,在PV系统应用框图,STEVAL-ISV001V1系统指标,电路图和材料清单以及所用变压器电感技术指标,PCB布局图.
1000 W dual stage DC-AC converter demonstration board based on the STP160N75F3
This application note provides design guidelines and performance characterization of the STEVAL-ISV001V1 demonstration board.
This board implements a 1 kW dual stage DC-AC converter, suitable for use in batterypowered uninterruptible power supplies (UPS) or photovoltaic (PV) standalone systems.
The converter is fed by a low DC input voltage varying from 20 V to 28 V, and is capable of supplying up to 1 kW of output power on a single-phase AC load. These features are possible thanks to a dual stage conversion topology that includes an efficient step-up pushpull DC-DC converter, which produces a regulated high-voltage DC bus and a sinusoidal HBridge PWM inverter to generate a 50 Hz, 230 Vrms output sine wave. Other key features of the system proposed are high power density, high switching frequency and efficiency greater than 90% over a wide output load range
图1.1 kW DC-AC转换器外形图
图2.DC-AC转换器在光伏转换中的应用框图
图3.DC/AC转换器系统框图
STEVAL-ISV001V1系统指标:
图4.STEVAL-ISV001V1电路
STEVAL-ISV001V1材料清单:
1.5 mH 2.5 A电感L4技术指标(MAGNETICA制造)
1kW 100kHz开关电源变压器TX1技术指标(MAGNETICA制造)
图5.STEVAL-ISV001V1元件布局图
详情请见:
CD00201961.pdf (3.05 MB)
来源:网络
本文地址:https://www.eechina.com/thread-95726-1-1.html     【打印本页】
  • AOE | 时钟与时序(5/7):什么是稳定性?
  • 初学者在电源电路设计中常犯的错误(以及如何避免)
  • AOE | 时钟与时序(3/7):什么是时钟相位?
