ZCC2601 带EN脚 60V LDO
发布时间:2025-1-16 18:04    发布者:四维电子
关键词: 带EN脚 , 60V , LDO
Describe
The ZCC2601 ultra-low quiescent currentregulator features low dropout voltage and lowcurrent in the standby mode. With less than 5μAquiescent current at no load, the ZCC2601 is ideallysuited for standby miZCCo-control-unit systems,especially for always-on applications like E-meters,fire alarms, smoke detectors and other batteryoperated systems. The ZCC2601 retains all ofthe features that are common to low dropoutregulators including a low dropout PMOS passdevice, short circuit protection, and thermalshutdown.The ZCC2601 has a 65-V maximumoperating voltage limit, a -40°C to 125°Coperating temperature range, and ±2%output voltage tolerance.
Features
⚫ VIN Range up to 60V
⚫ Output Voltage Tolerances of ±2%
⚫ Output Current of 150 mA
⚫ Ultra Low Quiescent Current (IQ = 2.8 μA)
⚫ Dropout Voltage Typically 1300 mV at IOUT = 100 mA
⚫ Internal Thermal Overload Protection
Applications
⚫ Internal Short-Circuit Current Limit
⚫ Ceramic Capacitor StableApplications
⚫ E-meters, Water Meters and Gas Meters
⚫ Fire Alarm, Smoke Detector
⚫ Appliances and White Goods
本文地址:https://www.eechina.com/thread-880661-1-1.html     【打印本页】
