查看: 819|回复: 0
[供应] IPQ5322 and IPQ9574 motherboard with QCN9274 network card High performance wireless network solution
发表于 2024-6-17 13:28:04 | 显示全部楼层 |阅读模式
关键词: wifi7
IPQ5322 and IPQ9574 motherboard with QCN9274 network card High performance wireless network solution:
In today's fast-paced digital age, high-performance, stable wireless networks are critical for both home and business users. In order to meet the needs of users for higher bandwidth and more stable connections, Qualcomm has launched two high-performance chip motherboards, IPQ5322 and IPQ9574, and is equipped with QCN9274 wireless network cards to provide excellent wireless network experience. This article will detail the features and differences of these two chip motherboards, as well as their advantages when paired with the QCN9274 network card.
#### IPQ5322chip mainboard
The IPQ5322 is Qualcomm's mid-to-high-end wireless networking chip designed for homes and small and medium-sized businesses that require high performance and stable connectivity. Its main features include:
1. ** High-performance CPU** : The IPQ5322 is equipped with a quad-core ARM Cortex-A53 processor with a clock rate of up to 1.8GHz, providing powerful computing power and the ability to easily handle multi-tasking and high-load applications.
2. ** Dual-Band Wi-Fi support ** : Support 2.4GHz and 5GHz dual-band Wi-Fi with maximum throughput of 600Mbps and 1200Mbps respectively, ensuring high-speed wireless connectivity in a variety of usage scenarios.
3. ** Advanced Network security features ** : Built-in a variety of network security features, including firewall, VPN acceleration and parental control, to ensure network security.
4. ** Low power design ** : The use of advanced process technology, with excellent energy efficiency performance, suitable for long-term operation, especially for home routers and small and medium-sized enterprise gateways.
#### IPQ9574 Chip mainboard
The IPQ9574 is the latest generation of Qualcomm's flagship wireless networking chip, designed for high-end market and large enterprise applications. Its main features include:
1. ** Top performance CPU** : The IPQ9574 is equipped with a quad-core ARM Cortex-A73 processor with a clock rate of up to 2.2GHz, which is more powerful than the IPQ5322 and can handle more complex network requirements and higher concurrent connections.
2. ** Tri-band Wi-Fi support ** : Support 2.4GHz, 5GHz and 6GHz tri-band Wi-Fi with maximum throughput of 1200Mbps, 4800Mbps and 9600Mbps respectively, especially suitable for large enterprises and high-density user environments requiring ultra-high-speed wireless connections.
3. ** Advanced Network features ** : Support for more enterprise-class network features, such as advanced QoS (quality of Service), support for up to 16 SSIDs (wireless network names), stronger VPN support and more comprehensive security features.
4. ** Enterprise-class reliability ** : The design emphasizes high reliability and high stability, suitable for large enterprise networks and data center environments, and can run uninterrupted for a long time.
#### QCN9274 Wireless network adapter
The QCN9274 is an advanced wireless card from Qualcomm designed for use with high-performance motherboards such as the IPQ5322 and IPQ9574. Its main features include:
1. **Wi-Fi 6E Support ** : Supports the latest Wi-Fi 6E standard, can work on the 6GHz band, providing higher bandwidth and lower latency, especially suitable for high-density environments and high bandwidth applications.
2. ** High throughput ** : Support 160MHz channel bandwidth, maximum throughput up to 2.4Gbps, to meet the growing bandwidth demand in the next few years.
3. ** Advanced antenna design ** : Support up to 8x8 MU-MIMO (multi-user multiple input multiple output) and OFDMA (orthogonal frequency division multiple access), providing higher concurrent connection capabilities and better network efficiency.
4. ** Low power consumption and high integration ** : Using advanced process technology, with excellent energy efficiency and high integration, suitable for a variety of device forms, such as routers, access points and gateway devices.
#### Special differentiator for IPQ5322 and IPQ9574 motherboards with QCN9274 network cards
1. ** Processor performance Differences ** : The IPQ9574 uses a higher performance ARM Cortex-A73 processor with higher frequencies for more complex and heavy load applications. While the IPQ5322's Cortex-A53 processor is slightly less powerful, it is more energy efficient and suitable for home and small and medium-sized businesses.
2. ** Band support ** : The IPQ9574 supports tri-band Wi-Fi, including the latest 6GHz band, which provides higher bandwidth and lower interference. The IPQ5322 only supports dual-band Wi-Fi, which is sufficient for most homes and small and medium businesses, but underperforms in high-density user environments.
3. ** Throughput and concurrent connections ** : The IPQ9574's overall throughput and concurrent connections are stronger, suitable for large enterprises and high-density environments. Although the IPQ5322 is slightly inadequate in this regard, its performance and energy efficiency balance is very suitable for ordinary households and small and medium-sized enterprises.
4. ** Network features and security ** : IPQ9574 provides more enterprise-class network features and more comprehensive security support, suitable for enterprise users who need complex network configurations and high security. The IPQ5322 is slightly inferior in network functionality and security, but it is enough to meet the needs of most homes and small and medium-sized enterprises.
#### Summary
Both the IPQ5322 and IPQ9574 motherboards combined with the QCN9274 network card provide superior wireless network performance and stability. The IPQ5322 motherboard with the QCN9274 network card is more suitable for home and small and medium-sized enterprise users, providing efficient and cost-effective wireless network solutions. The IPQ9574 motherboard, paired with the QCN9274 network card, is designed for large enterprises and high-density environments to deliver top performance and state-of-the-art networking features to meet the most demanding networking needs.
Choosing the right wireless network equipment can greatly improve the user's network experience, whether it is home entertainment, remote work or enterprise applications, Qualcomm's IPQ5322 and IPQ9574 motherboards with QCN9274 network cards are your ideal choice.
Hopefully, this article will help you better understand the features and differences between the IPQ5322 and IPQ9574 chip motherboards and QCN9274 network cards. If you have any questions or need further information, please feel free to contact us.
Wallys software technology advantages:
Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.
Hardware technology advantages:
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
