查看: 519|回复: 0
[供应] IPQ9574 work with QCN9274 cpu DR9574 router + DR9274-6G HOW HIGH CAN the throughput UP TO?
发表于 2024-2-28 14:02:42 | 显示全部楼层 |阅读模式
[color=rgba(0, 0, 0, 0.9)]Generally speaking, the higher the throughput of a WiFi router, the better its performance will usually be. Higher throughput means that the router can provide faster data transfer rates, allowing more devices to connect simultaneously and transfer data at high speeds.
[color=rgba(0, 0, 0, 0.9)]High-throughput routers can provide more stable and faster wireless connections and are suitable for applications with high bandwidth requirements, such as high-definition video streaming, online gaming, and large file downloads. If you have multiple devices connected to your WiFi network at the same time and need to transfer a lot of data, a router with high throughput will be better able to meet your needs.
[color=rgba(0, 0, 0, 0.9)]as you see,throughput up to 8.9G , If the environment is better, it can reach 9G+, close to 10G.
[color=rgba(0, 0, 0, 0.9)]Wallys had tested WiFi7 router DR9574 and WiFi7 moudle DR9274-6G throughput。
[color=rgba(0, 0, 0, 0.9)]DR9574 routerboard
[color=rgba(0, 0, 0, 0.9)]802.11be [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]IPQ9574 4x4 2.4G 2x10G +4x1G Ethernet Port
[color=rgba(0, 0, 0, 0.9)]Support WIFI7 card QCN9274-QCN6274
[color=rgba(0, 0, 0, 0.9)]DBDC 2x2 2.4G& 2x2 5G
[color=rgba(0, 0, 0, 0.9)]DBDC 2x2 5G& 2x2 6G
[color=rgba(0, 0, 0, 0.9)]single band 4x4 5G
[color=rgba(0, 0, 0, 0.9)]single band 4x4 6G
[color=rgba(0, 0, 0, 0.9)]WLAN Host InterfaceCI Express 3.0 Interface
[color=rgba(0, 0, 0, 0.9)]Frequency Range:2.4GHz: 2.412~2.472GHz
[color=rgba(0, 0, 0, 0.9)]DR9274-6G
[color=rgba(0, 0, 0, 0.9)]DR9274-6G based on [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]QCN9274 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO single Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RFenvironment in factories, warehouses establishment
[color=rgba(0, 0, 0, 0.9)]4x4 6G MU-MIMO WiFi Module
[color=rgba(0, 0, 0, 0.9)]WIFI7 M.2 card QCN9274
[color=rgba(0, 0, 0, 0.9)]■ Qualcomm Atheros QCN9274 for Industrial Grade;
[color=rgba(0, 0, 0, 0.9)]Maxim Tx power 22dBm per chain;
[color=rgba(0, 0, 0, 0.9)]■ 4x4  6G MU-MIMO, up to 11530Mbps physical data rate;
[color=rgba(0, 0, 0, 0.9)]■ Support up to 4096-QAM;
[color=rgba(0, 0, 0, 0.9)]■ M.2 connector;
[color=rgba(0, 0, 0, 0.9)]■ PCI Express 3 .0 Interface
DR9274-6G
[color=rgba(0, 0, 0, 0.9)]Wallys software technology advantages:
[color=rgba(0, 0, 0, 0.9)]Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.
[color=rgba(0, 0, 0, 0.9)]Hardware technology advantages:
[color=rgba(0, 0, 0, 0.9)]We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
[color=rgba(0, 0, 0, 0.9)]Clients: TIP,Facebook, Openwrt, etc
[color=rgba(0, 0, 0, 0.9)]Email:[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales@wallystech.com
[color=rgba(0, 0, 0, 0.9)]WEB:[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]https://www.wallystech.com/
