查看: 675|回复: 0
[供应] WiFi7 solution-IPQ9574 IPQ9554 CPU Different - Beyond imagination speed
发表于 2024-2-26 10:17:31 | 显示全部楼层 |阅读模式
Technical understanding of WiFi7:
Radio wave focusing technology: WiFi7 uses radio wave focusing technology to focus the signal on the desired area, thereby improving signal strength and coverage.
Multi-user multiple-input multiple-output technology: WiFi7 uses multi-user multiple-input multiple-output technology, which can send data to multiple devices at the same time, improving network capacity and efficiency.
Artificial Intelligence optimization: WiFi7 can also optimize the network through artificial intelligence technology, making intelligent adjustments according to the user's usage habits and network load, improving network performance and user experience.
Energy efficiency: WiFi7 uses more advanced energy management technologies to reduce energy consumption and carbon emissions while maintaining network performance.
The description of these special points can provide a deeper understanding of the technology and advantages of WiFi7, so that users can better understand its importance and application prospects in future wireless networks.
IPQ9574 and IPQ9554 are both wireless network chips launched by Qualcomm, and their main differences lie in the following aspects:
Processor performance: The IPQ9574 uses a higher performance quad-core processor with a speed of up to 2.2GHz, while the IPQ9554 uses a quad-core processor with a speed of 1.4GHz. As a result, the IPQ9574 is faster and smoother when handling large amounts of data.
Network speed: The IPQ9574 supports higher network speeds up to 4.8Gbps, compared to 1.7Gbps for the IPQ9554. Therefore, the IPQ9574 can provide faster wireless network speed and higher bandwidth.
Supported bands: The IPQ9574 supports more bands, including 2.4GHz and 5GHz bands, as well as higher 5GHz bands such as 6GHz and 60GHz. The IPQ9554 only supports 2.4GHz and 5GHz bands. Therefore, the IPQ9574 can provide a wider range of wireless network coverage.
Number of supported devices: The IPQ9574 supports more device connections, up to 256 devices, while the IPQ9554 can only connect 128 devices. Therefore, the IPQ9574 can better meet the needs of multi-device connectivity.
Overall, the IPQ9574 offers higher processor performance, faster network speeds, wider band support, and more device connection support than the IPQ9554. These advantages make the IPQ9574 a higher-end wireless networking chip for more demanding application scenarios.
