查看: 788|回复: 0
[供应] (至诚微)ZCC2467,3.0A, 40V, 500kHz,Step-Down Converter,Alternative MP2467
发表于 2024-1-30 17:44:15 | 显示全部楼层 |阅读模式
关键词: ZCC2467 , 至诚微 , Step-Down Converter
DESCRIPTION
▲ The ZCC2467 is a high frequency step-down switching regulator with integrated
▲ internal high-side, high voltage power MOSFET. It provides 3.0A output with
▲ current mode control for fast loop response and easy compensation.
▲ The wide 6V to 40V input range accommodates a variety of step-down
▲ applications, including those in automotive systems. A 100μA operational
▲ quiescent current allows use in battery-powered applications.
▲ High power conversion efficiency over a wide load range is achieved by
▲ scaling down the switching frequency at light load condition to reduce the
▲ switching and gate driving losses.
▲ The frequency foldback prevents inductor current runaway during startup and
▲ thermal shutdown provides reliable, fault tolerant operation.
▲ The ZCC2467 is available in thermally enhanced SOIC8 package.
FEATURES
● 100μA Quiescent Current
● Wide 6V to 40V Operating Input Range
● 150mΩ Internal Power MOSFET
● 500kHz Fixed Switching Frequency
● Ceramic Capacitor Stable
● Internal Soft-Start
● Precision Current Limit without a Current Sensing Resistor
● Up to 95% Efficiency
● Output Adjustable from 0.8V to 30V
● Available in SOIC8 with Exposed Pad Packages
APPLICATIONS
● Game Machines
● Automotive Systems
● Industrial Power Systems
● Distributed Power Systems
● Printer Systems
● Battery Powered Systems
Original factory authorized agent
Wu R♂:19928734273【WeChat synchronization】
QQ:3557033601
