查看: 588|回复: 0
[供应] IPQ9574-IPQ8072 has 10G Ethernet port- What is the performance difference?
发表于 2023-12-26 10:29:59 | 显示全部楼层 |阅读模式
At present, most routers have 1G Ethernet ports, but many projects require routers to have 10G network ports. So what is the difference between 10G network ports and 1G network ports?
There are some significant differences between the 10G network port and the 1G network port on the router, which are mainly reflected in the following aspects:
transfer speed:
10G network port: Supports a maximum transmission speed of 10 Gbps (gigabits per second), which is 10 times the speed of the 1G network port.
1G network port: The maximum transmission speed is 1 Gbps.
bandwidth:
10G network port: It has larger bandwidth and is suitable for scenarios that require high bandwidth, such as data centers and large enterprise networks.
1G network port: Provides smaller bandwidth and is suitable for the network needs of ordinary homes, small businesses or general offices.
cost:
10G network port: Generally more expensive than 1G network port because it provides higher performance.
1G network port: Relatively economical and suitable for general network needs.
Device support:
10G network port: Network equipment that supports 10G is required, including network cards, switches, optical fibers, etc., and the equipment cost is relatively high.
1G network port: It is more popular, the equipment supporting 1G is more widespread, and the corresponding equipment cost is relatively low.
Applicable scene:
10G network port: Suitable for scenarios with high demand for network bandwidth, such as large-scale data transmission, video editing, scientific computing, etc.
1G network port: Suitable for general office, home networks and small business networks.
compatibility:
10G network port: It is necessary to ensure that all related equipment is compatible with and supports the 10G network.
1G network port: The compatibility is relatively better because 1G network is a more common and widely used standard.
Generally speaking, whether to choose a 10G network port or a 1G network port depends on the network requirements. For general users and small businesses, the 1G network port is enough to meet daily needs. For professional applications that require higher bandwidth and performance, such as data centers or large enterprise networks, you may choose higher-speed 10G network ports.
The following is based on the current requirements of many projects that require high-performance routers. The difference between IPQ9574 and IPQ8072 is that they both have 10G Ethernet ports.
IPQ9574 and IPQ8072 are both different chips that have 10G Ethernet ports. The main difference between these two chips is their architecture and the number of cores they have.
The IPQ9574 is a quad-core chip that is designed for high-performance networking applications. It has a clock speed of up to 2.2 GHz and supports up to 4x4 MU-MIMO. It also has a built-in 10G Ethernet port, which makes it ideal for high-speed networking applications.
Support WIFI7 card QCN9274-QCN6274 2x2 2.4G& 2x2 5.8G 2x2 5G& 2x2 6G
802.11be IPQ9574 4x4 2.4G 2x10G +4x1G Ethernet Port
DR9574
On the other hand, the IPQ8072 is a dual-core chip that is designed for lower-power networking applications. It has a clock speed of up to 1.8 GHz and supports up to 2x2 MU-MIMO. It also has a built-in 10G Ethernet port, which makes it ideal for low-power networking applications that require high-speed connectivity.
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
DR8072
In summary, the main difference between these two chips is their architecture and the number of cores they have. The IPQ9574 is designed for high-performance networking applications, while the IPQ8072 is designed for lower-power networking applications.
Wallys software technology advantages:
Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.
Hardware technology advantages:
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
