查看: 510|回复: 0
[供应] ZCC1005Q 100V Input,5A Output, Synchronous Step-down Converter
发表于 2023-10-18 17:02:24 | 显示全部楼层 |阅读模式
Features
l 9V to 100V input voltage range
l 5A continuous output current
l 96% Peak Efficiency
l 500µA operating quiescent current
l Peak Current mode control
l 100V 20-mΩ high-side and low-side MOSFET
l 150 kHz Fixed Frequency
l Internal compensation for ease of use
l Up to 91% duty cycle
l 0.8V voltage reference
l 9µA shutdown current
l 150ms Hiccup mode short circuit protection
l Thermal shutdown Function
l QFN-20 package
Description
The ZCC1005Q is a high voltage, synchronous step-down controller operates over a wide range input voltage 9V to 100V. The ZCC1005Q delivers 5A continuous load current with up to 96% efficiency. The ZCC1005Q operates with fixed frequency peak current control with built-in compensation eliminates the need for external components. Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time. The ZCC1005Q exhibits protection features that protect the load from faults like under-voltage,over-current and over-temperature. The ZCC1005Q is available in an QFN-20.
