查看: 508|回复: 0
[供应] ZCC1008B 100V Input,10A Output, Synchronous Step-down Converter
发表于 2023-10-18 15:28:00 | 显示全部楼层 |阅读模式
Features
l 9V to 100V input voltage range
l 10A continuous output current
l 96% Peak Efficiency
l 500µA operating quiescent current
l Peak Current mode control
l 150 kHz Fixed Frequency
l Internal compensation for ease of use
l Up to 91% duty cycle
l 0.8V voltage reference
l 9µA shutdown current
l 150ms Hiccup mode short circuit protection Function
l Thermal shutdown Function
l MSOP-10 package
Description
The ZCC1008B is a high voltage, synchronous step-down controller operates over a wide range input voltage 9V to 100V. The ZCC1008B delivers 10A continuous load current with up to 96% efficiency. The ZCC1008B operates with fixed frequency peak current control with built-in compensation eliminates the need for external components. Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time. The ZCC1008B exhibits protection feature that protect the load from faults like under-voltage,over-current and over-temperature. The ZCC1008B is available in an MSOP-10.
