查看: 529|回复: 0
[供应] ZCC6688 3A Synchronous Buck Li-ion Charger
发表于 2023-8-23 15:45:43 | 显示全部楼层 |阅读模式
关键词: 同步降压型充电管理
General Description
The ZCC6688 is a 3A Li-Ion battery charger. It utilizes a 500KHz synchronous buck converter topology to reduce power dissipation during charging. Low power dissipation, an internal MOSFET allow a physically small charger that can be embedded in a wide range of handheld applications. The ZCC6688 includes complete charge termination circuitry, automatic recharge and a ±1% 4.2V /8.4V float voltage. Battery charge current, charge timeout and end-of- charge indication parameters are set with external components. Additional features include shorted cell detection; temperature qualified charging and overvoltage protection. The ZCC6688 is available in a low profile ESOP10 package.
Features
u Input voltage range 4V~10V
u Dynamic input current allocation for maximum charging rate
u 3.0A Maximum Charge Current
u No External MOSFETs and Blocking Diode Required
u Efficiency up to 90%
u Constant-Current/Constant-Voltage Operation with Thermal Regulation to Maximize Charge Rate Without Risk of Overheating
u Optional Battery Temperature Monitoring Before and During Charge Automatic Sleep Mode for  Low-Power
u Over Current Protection
u Consumption Available in ESOP10
u RoHS Compliant and 100% Lead (Pb)-Free
