查看: 633|回复: 0
[供应] ZC811 reset芯片替代MAX811
发表于 2023-8-15 11:21:28 | 显示全部楼层 |阅读模式
关键词: 811
Description
The ZC811is a low-power microprocessor (μP) supervisory circuit used to monitor power suppliesin microprocessor and digital systems. Low supply current makes the ZC811ideal for use in portable equipment. The device comes in a 4-pin SOT-143 package. The ZC811provides excellent circuit reliability and low BOM cost by eliminating external components and adjustments when used with 5V-powered or 3V-powered circuits. The ZC811also provides a debounced manual reset input.
The function of this device is to assert a reset if either the power supply drops below a designed reset threshold level or MR is forced low. Thereset comparator is designed to ignore fast transients on VCC. Reset thresholds are available for operation with a variety of supply voltages.
Features
• Precision voltage monitor for 3V, 3.3V or 5V power supplies 1V
•140ms minimum reset pulse widt
• Reset remains valid with VCC as low as havailable
•3μA typical supply current
• Available in 4-pin SOT-143 package
Applications
l •Computer
l •Controller
l• Intelligent Instruments
l• Critical uP and uC Power Monitoring
l• Portable/Battery-Powered Equipment
