查看: 499|回复: 0
[供应] 陶瓷移印专业知识
发表于 2023-8-9 11:56:33 | 显示全部楼层 |阅读模式
陶瓷移印专业知识
                            2014年2月28日编辑
一 陶瓷移印产品
主要是餐具  陶瓷碗、盘子等
江苏宜兴、广东潮州 陶瓷产品之乡、而且绝大部分都用于出口。
陶瓷产品是如何做出来的?
陶瓷产品都是泥巴制成的
1 原料
陶瓷泥制作  (最初的粉体等各种原料)
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
再根据做的不同产品类型、生产出不同形状的瓷泥
做盘子、做碗、做杯子等 用机器压制出来
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpgfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image005.png
2 原料
生产各种类型产品用的模具
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image007.jpg
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image009.jpg
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image010.pngfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg
3 利用模具生产陶瓷毛坯
陶瓷模具
钻头
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image013.pngfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image014.png
生产陶瓷盘子file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image018.jpgfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image020.jpg
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image021.pngfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image022.png
4 上色
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image024.jpgfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image025.png
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image026.pngfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image027.png
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image028.png file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image029.png
制作瓷器的完整流程,一般要经过如下几道工序。
练泥:将瓷胎的原料——高岭土、瓷石经过磨洗、除杂揉匀后调和成为用于制作瓷器的瓷泥
制坯:将调质的瓷泥经过模具等制成所须要的瓷器的外形,将坯胎凉至半干后至于车盘,用刀旋削表面,保证瓷器外表的光洁。最后在依照需要使用材质不同(铁、骨、木等材料)的雕花刀在外表刻出花纹。
上釉:依照瓷器的几何外形有不同的上釉方式。圆口瓷器(指通过拉坯方法成型的口径较圆的器皿种类)将瓷胎浸泡在釉浆中。大一些的瓷器或者形状不规则的瓷器,采用吹釉的方式上釉。无论采用何种方式,保证釉浆的均匀分散是重要的一点。釉下彩:一般家用瓷器和中国元代青花瓷器均属此类: 将颜料直接涂在未上釉的瓷胎上,再进行上釉。由于颜料被包裹在釉之下,使得色彩能够长期保存,并不易被磨损。但由于施加釉下彩将使颜料经过约1天的高温灼烧,会导致部分瓷器颜色变化,因而釉下彩的瓷器颜色变化较多。
釉上彩:将未上色的瓷胎途釉后放入窑内烧结为素瓷,待冷却后再进行上色,并放入相对低温(约700℃—900℃)的窑炉中进行二次烧结。这样的做法能够保证釉彩的花纹和颜色丰富多彩,但长期暴晒或使用会导致表面磨损,导致颜色脱落。
胶头移印制作
陶瓷移印胶头
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image031.jpg
陶瓷移印胶头
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image033.jpg
胶头底拖
胶头陶瓷膜具
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image034.pngfile:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image035.png
胶头工作面坏了可以修补
file:///C:/Users/Administrator/AppData/Local/Temp/msohtmlclip1/01/clip_image036.png
二、陶瓷移印硅胶:硅胶量可以添加到180%,做出的胶头柔软,弹性好、移印次数多、胶头不变形。胶头不冒油
   一般客户的要求是:胶头不冒油
三、操作方法:
1、和基本的移印胶头制作方法一样。只是这个胶头可以做成工作面是916#软胶,底部是普通的硅胶。
四、市场价格定位
一般客户都是生产陶瓷产品的厂家,自己工厂有移印机的才能用到 市场指导价为:80--100元/KG
五、客户开发
客户群一般客户集中在江苏和广东潮州一带。一般客户也会用模具硅胶用于最初的陶瓷模具、但是用量不是很大。
常用关键词:陶瓷厂 陶瓷餐具
