KEYSIGHT是德N9020B 频谱分析仪(526/B1X/544选件) N9020B-MXA矢量信号分析仪 JIANG N9020B-RT1 高达 85 MHz 带宽的实时分析,基本检测,多点触控频率选件3.6、8.4、13.6、26.5 GHz,使用混频器可达 1.1 THz 最大分析带宽160 MHz 带宽选件25 MHz 标配,40、85、125、160 MHz 最大实时带宽160 MHz 实时带宽选件85, 125, 160 MHz 产品介绍 N9020B-RT1 高达 85 MHz 带宽的实时分析多点触控 1 GHz 时的 DANL-166 dBm 1 GHz 时,10 kHz 频偏处的相位噪声-114dBc/Hz 1 GHz 时,30 kHz 频偏处的相位噪声-114dBc/Hz 1 GHz 时,1 MHz 频偏处的相位噪声-136dBc/Hz 总体幅度精度±0.23 dB 三阶截获(TOI),1 GHz 时+20 dBm 1 GHz 时的最大三阶动态范围116 dB 仪器类型频谱分析仪 应用——通用89600 VSA 软件 模拟解调 噪声系数 相位噪声 脉冲 实时频谱分析 MATLAB 应用——蜂窝GSM/EDGE NB-IoT W-CDMA/HSPA/HSPA+ Frequency range N9020B-503 Frequency Range, 10 Hz to 3.6 GHz N9020B-508 Frequency Range, 10 Hz to 8.4 GHz N9020B-513 Frequency Range, 10 Hz to 13.6 GHz N9020B-526 Frequency Range, 10 Hz to 26.5 GHz N9020B-532 Frequency Range, 10 Hz to 32 GHz N9020B-544 Frequency Range, 10 Hz to 44 GHz N9020B-550 Frequency Range, 10 Hz to 50 GHz Preamplifier N9020B-P03 Preamplifier, 3.6 GHz N9020B-P08 Preamplifier, 8.4 GHz N9020B-P13 Preamplifier, 13.6 GHz N9020B-P26 Preamplifier, 26.5 GHz N9020B-P32 Preamplifier, 32 GHz N9020B-P44 Preamplifier, 44 GHz N9020B-P50 Preamplifier, 50 GHz Bandwidth N9020B-B1A Analysis Bandwidth, 125 MHz N9020B-B1X Analysis Bandwidth, 160 Mhz N9020B-B40 Analysis Bandwidth, 40 MHz N9020B-B85 Analysis Bandwidth, 85 MHz Performance Options N9020B-FT2 Frequency Mask Trigger, OptimumDetection License N9020B-MPB Microwave Preselector Bypass N9020B-NF2 Noise Floor Extension N9020B-PFR Precision Frequency Reference N9020B-TDS Time Domain Scan N9020B-DP2 Deep Capture Memory N9020B-EA3 Electronic Attenuator, 3.6 GHz,Upgrade N9020B-EDP Enhanced Display Package License N9020B-EMC Basic EMC Functionality License N9020B-FP2 Fast Power, Up To 40 MHz Bandwidth N9020B-FT1 Frequency Mask Trigger, BasicDetection License N9020B-RBE Resolution Bandwidth Extended Baseband Inputs N9020B-BBA I/Q Baseband Inputs, Analog Calibration Options N9020B-AMG Calibration + Uncertainties +Guardbanding (Accredited) N9020B-A6J ANSI Z540-1-1994 Calibration N9020B-UK6 Commercial Calibration Certificatewith Test Data Connection Options N9020B-CR3 Connector, Wideband IF Output N9020B-CRP Connector, Programmable Rear IFOutput N9020B-YAS Y-Axis Ouptut External Mixing N9020B-EXM External Mixing Real time signal analysis N9020B-RT1 Real-time analysis up to maximumavailable BW, basic detection license N9020B-RT2 Real-time analysis up to maximumavailable BW, optimum detection, license Portable Packaging N9020B-PRC Portable Configuration Security – PC features N9020B-SF2 Security F谭S 135-1007-5188(微信同号) 技术咨询:蒋工135-1007-5288(微信同号)
电 话:0755-21502766 传 真:0755-21502722
客 服QQ:53540923
