查看: 775|回复: 0
[供应] IPQ8072A+QCN9074 One of the most powerful network processors up to 10 Gbps data transfer rate
发表于 2023-4-27 11:47:39 | 显示全部楼层 |阅读模式
关键词: router
IPQ8072A is a high-performance network processor launched by Qualcomm. It is a member of the Qualcomm family of network processors and one of the most powerful network processors on the market today.
IPQ8072A has powerful processing capability and efficient network connection capability. It uses a 64-bit ARM Cortex-A53 processor core, clocked at up to 2.2 GHz. At the same time, it is also equipped with an Adreno 650 GPU that supports video processing at up to 4K resolution.
In terms of network connection, IPQ8072A supports multiple connection methods, including 2.5G and 5G Ethernet, 802.11ax Wi-Fi, Bluetooth 5.2, etc. It also supports a variety of network security technologies, such as WPA3, TLS, DTLS, etc., which can ensure the security of the network.
2.4GHz band:
The 2.4GHz frequency band is the earliest frequency band used by Wi-Fi. Its advantage is that the signal has a wide range of transmission and strong penetrating power, and can pass through some obstacles, such as walls and ceilings. use of indoor space. However, since its frequency band is used by numerous devices (such as Bluetooth, microwave ovens, etc.), it may be subject to interference, so its speed and stability may be affected.
5GHz band:
The 5GHz frequency band is an increasingly popular Wi-Fi frequency band in recent years, and its main advantage is wider channels, which can provide higher speeds and more stable connections. Because its frequency band is not widely used by other devices, it has less interference and higher reliability. However, the signal propagation range of 5GHz is relatively small, and the penetration is relatively weak, so it is suitable for use in small indoor spaces.
In addition, IPQ8072A also supports up to 10 Gbps data transmission rate, and adopts Qualcomm's unique technologies, such as MU-MIMO, OFDMA, TxBF, etc., which can improve the throughput and stability of the network.
Among them, MU-MIMO technology can send a wireless channel to multiple devices at the same time, which improves the efficiency of the network; OFDMA technology can divide a channel into multiple sub-channels, so that multiple devices can communicate at the same time, improving the throughput of the network ; TxBF technology can optimize the directivity of the antenna, improve the stability of the signal and the transmission distance.
IPQ8072A can be used with Wi-Fi 6E network card to achieve faster wireless transmission speed and more stable connection quality. Wi-Fi 6E is an upgraded version of Wi-Fi 6, which adds more wireless frequency bands in the 6GHz frequency band, avoids the congestion of the 2.4GHz and 5GHz frequency bands, and provides wider frequency bands and more channels, so that more High data transfer rate and more stable connection quality.
IPQ8072A supports Wi-Fi 6E technology and can be used with Wi-Fi 6E network cards to achieve data transfer rates up to 10 Gbps and more stable connection quality. At the same time, Wi-Fi 6E also supports more device connections, which can better cope with the large number of devices connected at the same time in scenarios such as smart home and industrial automation.
Wallys software technology advantages:Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.Hardware technology advantages:We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.Clients: TIP,Facebook, Openwrt, etcEmail:sales@wallystech.comWEB:https://www.wallystech.com/
