查看: 754|回复: 0
[供应] VK1623 is fully compatible with 1623 on the market,48SEG*8COM LCD driver
发表于 2023-4-13 11:10:35 | 显示全部楼层 |阅读模式
Model:VK1623S
Specifications:LQFP100/QFP100、DICE/DIE/COG
Product year:Latest year
Contacts:Chandan
QQ:3618885898
WeChat:crh_chip888
E-mail:crh-chip@szvinka.com
General Description:
VK1623S is a RAM Mapping 48x8 LCDDriver,It can support LCDscreens with a maximum of 384 pattern(48SEGx8COM).Only 3 or 4 lines arerequired to communication interface with the VK1623S,it is used to configuredisplay parameters and transfer display data, and can also enter the standbymode through Power down command(by Cmd LCD OFF,SYS DIS).
Features:
• Operatingvoltage:2.4-5.2V
• Built-in32kHz RC oscillator(default)
• External32.768kHz crystal(OSCO,OSCI)
• 1/4BIAS
• 1/8duty (8 COM)
• Built-in48×8 bit display RAM
• Selectionof buzzer frequencies 2kHz、4kHz
• STANDBYmode(by Cmd LCD OFF,SYSDIS)
• 8kinds of time base/WDT clock sources
• Timebase or WDT overflow output (/IRQ pin)
• 3 or 4 wire serial interface
• Softwareconfiguration LCD parameters
• Datamode and command mode instructions
• Read/Writeaddress auto increment
• Threedata accessing modes
• VLCDpin for adjusting LCD operating voltage(
• Package:
LQFP100(14.0mm x 14.0mm PP=0.5mm)
QFP100(20.0mm x 14.0mm PP=0.65mm)
DICE/DIE/COG
VK1621S-1_V1.3-EN.pdf (3.51 MB)
VK1622S_V1.3-EN.zip (9.12 MB)
VK1625_V1.3-EN.zip (2.23 MB)
RAMmapping LCD controller and driver
High cost performance LCD driver:
VK1024B  2.4V~5.2V   6seg*4com   6*3   6*2           Bias: 1/21/3   S0P-16
VK1056B  2.4V~5.2V   14seg*4com   14*3   14*2          Bias: 1/2 1/3   SOP-24/SSOP-24
VK1072B  2.4V~5.2V   18seg*4com   18*3    18*2          Bias: 1/21/3  SOP-28
VK1072C  2.4V~5.2V  18seg*4com   18*3   18*2          Bias: 1/2 1/3  SOP-28
VK1072D  2.4V~5.2V  18seg*4com   18*3   18*2          Bias: 1/2 1/3  SSOP-28
VK1088B  2.4V~5.2V  22seg*4com   22*3                Bias: 1/21/3   QFN-32L(4MM*4MM)
VK0192   2.4V~5.2V  24seg*8com                           Bias: 1/4     LQFP-44
VK0256   2.4V~5.2V  32seg*8com                           Bias: 1/4     QFP-64
VK0256B  2.4V~5.2V  32seg*8com                           Bias: 1/4      LQFP-64
VK0256C  2.4V~5.2V  32seg*8com                           Bias: 1/4     LQFP-52
VK1621     2.4V~5.2V  32seg*4com 32*3  32*2    Bias: 1/2  1/3   LQFP44/48/SSOP48/DICE
VK1622    2.7V~5.5V   32seg*8com         Bias: 1/4     LQFP44/48/52/64/QFP64/DICE
VK1623    2.4V~5.2V   48seg*8com             Bias: 1/4      LQFP-100/QFP-100/DICE
VK1625   2.4V~5.2V  64seg*8com         Bias: 1/4       LQFP-100/QFP-100/DICE
VK1626   2.4V~5.2V  48seg*16com         Bias: 1/5       LQFP-100/QFP-100/DICE
High anti-interferenceLCD driver:
VK2C21A  2.4~5.5V 20seg*4com  16*8      Bias: 1/3  1/4   I2C bus interface      SOP-28
VK2C21B  2.4~5.5V 16seg*4com  12*8     Bias: 1/3  1/4   I2C bus interface   SOP-24
VK2C21C  2.4~5.5V 12seg*4com  8*8      Bias:1/3  1/4   I2C bus interface   SOP-20
VK2C21D  2.4~5.5V  8seg*4com 4*8     Bias: 1/3  1/4   I2C bus interface   SOP-16
VK2C22A  2.4~5.5V  44seg*4com        Bias: 1/2  1/3  I2C bus interface   LQFP-52
VK2C22B  2.4~5.5V 40seg*4com       Bias: 1/2  1/3  I2C bus interface   LQFP-48
VK2C23A  2.4~5.5V 56seg*4com 52*8     Bias:1/3  1/4   I2C bus interface   LQFP-64
VK2C23B  2.4~5.5V 36seg*8com         Bias: 1/3  1/4   I2C bus interface   LQFP-48
VK2C24    2.4~5.5V 72seg*4com68*8 60*16 Bias: 1/3  1/4  1/5  I2C bus interface LQFP-80
VK2C24B   2.4~5.5V 56seg*4com 52*8 44*16 Bias: 1/3  1/4  1/5 I2C bus interface  LQFP-64
Ultra-lowpower consumption LCD driver:
VKL060   2.5~5.5V  15seg*4com      Bias: 1/2  1/3    I2C bus interface    SSOP-24
VKL128   2.5~5.5V  32seg*4com     Bias: 1/2  1/3     I2C bus interface     LQFP-44
VKL144A  2.5~5.5V  36seg*4com     Bias: 1/2  1/3     I2C bus interface     TSSOP-48
VKL144B  2.5~5.5V  36seg*4com      Bias: 1/2  1/3    I2C bus interface    QFN48L (6MM*6MM)
Static display  LCD  driver:
VKS118   2.4~5.2V   118seg*2com           Bias:---            4 wireserial interface     LQFP-128
VKS232   2.4~5.2V   116seg*2com           Bias: 1/1  1/2      4 wire serial interface     LQFP-128
RAMMapping LED display driver
VK16D32   3.0~5.5V  driver dot matrix:96    common cathode drive:8SEG*12GRID   common anodedrive:---   communicationinterface:SCL/SDA   quiescentcurrent /standby current:<1mA<10μA   matrix keys:---   package:SSOP24
VK16D33   3.0~5.5V  driver dot matrix:128   common cathode drive:8SEG*16GRID   common anodedrive:---   communicationinterface:SCL/SDA   quiescentcurrent /standby current:<1mA<10μA   matrix keys:---   package:SOP28
VK16K33   3.0~5.5V  driver dot matrix:128/96/64           common cathode drive:16SEG*8GRID;12SEG*8GRID;8SEG*8GRID    common anodedrive:8SEG*16GRID;8SEG*12GRID;8SEG*8GRID      communicationinterface:SCL/SDA   quiescentcurrent/standby current:<1mA<10μA
matrix keys:16*3  10*3 8*3   package:SOP28/24/20
VK1640    3.0~5.5V  driver dot matrix:128   common cathode drive:8SEG*16GRID   common anodedrive:16SEG*8GRID     communication interface:CLK/DIN
quiescentcurrent/standby current:<0.1mA/--       matrix keys:---   package:SOP28
VK1640A   3.0~5.5V  driver dot matrix:128   common cathode drive:8SEG*16GRID   common anodedrive:16SEG*8GRID     communication interface:CLK/DIN
quiescentcurrent/standby current:<0.1mA/--       matrix keys:---   package:SSOP28
VK1640B   3.0~5.5V  driver dot matrix:96    common cathode drive:8SEG*12GRID   common anodedrive:12SEG*8GRID     communication interface:CLK/DIN
quiescentcurrent/standby current:<0.1mA/--       matrix keys:---   package:SSOP24
VK1650    3.0~5.5V   driver dot matrix:32    common cathode drive:8SEG*4GRID   common anodedrive:4SEG*8GRID       communication interface:CLK/DAT
quiescentcurrent/standby current:typ.0.3mA/50μA   matrix keys:7*4   package:SOP16/DIP16
VK1Q60    3.0~5.5V   driver dot matrix:32    common cathode drive:8SEG*4GRID   common anodedrive:4SEG*8GRID       communication interface:CLK/DAT
quiescentcurrent/standby current:typ.0.3mA/50μA   matrix keys:7*4   package:QFN16
VK1651    3.0~5.5V  driver dot matrix:28    common cathode drive:4SEG*7GRID   common anodedrive:7SEG*4GRID       communication interface:CLK/DIO
quiescentcurrent/standby current:<5mA/--         matrix keys:7*1   package:SOP16/DIP16
VK1637
3.0~5.5V   driver dot matrix:48    common cathode drive:6SEG*8GRID   common anode drive:
8SEG*6GRID        communicationinterface:CLK/DIO
             quiescentcurrent/standby current:--/--            matrix keys:8*2   package:SOP20/DIP20
VK1616    3.0~5.5V  driver dot matrix:28    common cathode drive:7SEG*4GRID   common anodedrive:
4SEG*7GRID        communicationinterface:CLK/STB/DIO    quiescentcurrent/standby current:
<1mA/--        matrix keys:---   package:SOP16/DIP16       Stronganti-interference ability
VK1618    3.0~5.5V  driver dot matrix:35/36/35/32    common cathode drive:5SEG*7GRID;6SEG*6GRID;
7SEG*5GRID;8SEG*4GRID    commonanode drive:7SEG*5GRID;6SEG*6GRID;5SEG*7GRID;4SEG*8GRID
communicationinterface:CLK/STB/DIO    quiescentcurrent/standby current:<1mA/--
matrix keys:5*1   package:SOP18/DIP18       Strong anti-interference ability
VK1620B   3.0~5.5V  driver dot matrix:48/45/40      common cathode drive:8SEG*6GRID;9SEG*5GRID;
10SEG*4GRID   common anodedrive:6SEG*8GRID;5SEG*9GRID;4SEG*10GRID
matrix keys:---   package:SOP20             Strong anti-interference ability
VK1624    3.0~5.5V  driver dot matrix:77/72/65/56   common cathode drive:11SEG*7GRID;12SEG*6GRID;
13SEG*5GRID;14SEG*4GRID   common anode drive:7SEG*11GRID;6SEG*12GRID;5SEG*13GRID;4SEG*14
matrix keys:---   package:SOP24/DIP24       Strong anti-interference ability
VK1S68C   3.0~5.5V  driver dot matrix:70/66/60/52   common cathode drive:10SEG*7GRID;11SEG*6GRID;
12SEG*5GRID;13SEG*4GRID   commonanode drive:7SEG*10GRID;6SEG*11GRID;5SEG*12GRID;4SEG*13GRID
matrix keys:10*2  package:SSOP24            Strong anti-interference ability
VK1Q68D   3.0~5.5V  driver dot matrix:70/66/60/52   common cathode drive:10SEG*7GRID;11SEG*6GRID;
matrix keys:10*2  package:QFN24             Strong anti-interference ability
VK1668    3.0~5.5V  driver dot matrix:70/66/60/52   common cathode drive:10SEG*7GRID;11SEG*6GRID;
matrix keys:10*2  package:SOP24/SSOP24      Strong anti-interference ability
VK1628    3.0~5.5V  driver dot matrix:70/66/60/52   common cathode drive:10SEG*7GRID;11SEG*6GRID;
4SEG*13GRID     communicationinterface:CLK/STB/DIO    quiescentcurrent/standby current:
<1mA/--         matrix keys:10*2  package:SOP28             Stronganti-interference ability
VK1S38A   3.0~5.5V  driver dot matrix:64     common cathode drive:8SEG*8GRID    common anodedrive:
8SEG*8GRID   communicationinterface:CLK/STB/DIO   quiescentcurrent/standby current:<5mA/--
matrix keys:8*3   package:SSOP24            Strong anti-interference ability
VK1638    3.0~5.5V  driver dot matrix:80     common cathode drive:10SEG*8GRID    common anodedrive:
8SEG*10GRID   communicationinterface:CLK/STB/DIO   quiescentcurrent/standby current:<
5mA/--         matrix keys:8*3   package:SOP28             Stronganti-interference ability
VK1629    3.0~5.5V driver dot matrix:128  common cathode drive:16SEG*8GRID   common anode drive:
8SEG*16GRID   communicationinterface:CLK/STB/DIN/DOUT   quiescentcurrent/standby current:
<5mA/-- matrix keys:8*4   package:LQFP44(QFP44)         Strong anti-interference ability
VK1629A   3.0~5.5V  driver dot matrix:128     common cathode drive:16SEG*8GRID    common anodedrive:
8SEG*16GRID   communicationinterface:CLK/STB/DIO    quiescentcurrent/standby current:<
5mA/--         matrix keys:---   package:SOP32             Stronganti-interference ability
VK1629B   3.0~5.5V  driver dot matrix:112     common cathode drive:14SEG*8GRID    common anodedrive:
8SEG*14GRID   communicationinterface:CLK/STB/DIO   quiescentcurrent/standby current:<
5mA/--         matrix keys:8*2   package:SOP32             Stronganti-interference ability
VK1629C   3.0~5.5V  driver dot matrix:120     common cathode drive:15SEG*8GRID    common anodedrive:
8SEG*15GRID   communicationinterface:CLK/STB/DIO   quiescent current/standbycurrent:<
5mA/--         matrix keys:8*1   package:SOP32             Stronganti-interference ability
VK1629D   3.0~5.5V  driver dot matrix:96      common cathode drive:12SEG*8GRID    common anodedrive:
8SEG*12GRID   communicationinterface:CLK/STB/DIO   quiescentcurrent/standby current:<
5mA/--         matrix keys:8*4   package:SOP32             Stronganti-interference ability
VK6932    3.0~5.5V  driver dot matrix:128     common cathode drive:8SEG*16GRID    common anodedrive:
16SEG*8GRID   communicationinterface:CLK/STB/DIN   quiescentcurrent/standby current:<
0.1mA/--       matrix keys:---   package:SOP32             Stronganti-interference ability
(VINKAIC Factory,main businessLCD/LED driver ic;Touch ic; Water leveldetection ic; LDO regulated ic and other.Provide FAE technical support)
