查看: 629|回复: 0
[供应] VK1622 is a 32x8 LCD Driver,function and foot position as same as 1622 on the market, more cost-effective
发表于 2023-3-14 10:29:24 | 显示全部楼层 |阅读模式
Brand:VINKA
Model:VK1622S
Specifications:LQFP44/48/52/64、QFP64、DICE
Product year:Latest year
Contacts:Chandan
QQ:3618885898
WeChat:crh_chip888
E-mail:crh-chip@szvinka.com
General Description:
VK1622S is a RAM Mapping 32x8 LCDDriver,It can support LCDscreens with a maximum of 256 pattern(32SEGx8COM).Only 3 or 4 lines arerequired to communication interface with the VK1622S,it is used to configuredisplay parameters and transfer display data, and can also enter the standbymode through Power down command(by Cmd LCD OFF,SYS DIS)
Features:
• Operatingvoltage:2.4-5.2V
• Built-in32kHz RC oscillator(default)
• External32kHz requency source(OSCI)
• 1/4BIAS
• 1/8duty (8 COM)
• Built-in32×8 bit display RAM
• Selectionof buzzer frequencies 2kHz、4kHz
• STANDBYmode(by Cmd LCD OFF,SYSDIS)
• 8kinds of time base/WDT clock sources
• Timebase or WDT overflow output (/IRQ pin)
• 3or 4 wire serial interface
• Softwareconfiguration LCD parameters
• Datamode and command mode instructions
• Read/Writeaddress auto increment
• Threedata accessing modes
• VLCDpin for adjusting LCD operating voltage(
• Package:
LQFP44(10.0mm x 10.0mm PP=0.8mm)
LQFP48(7.0mm x 7.0mm PP=0.5mm)
LQFP52(14.0mm x 14.0mm PP=1.0mm)
LQFP64(7.0mm x 7.0mm PP=0.4mm)
QFP64(20.0mm x 14.0mm PP=1.0mm)
DICE
VK1622S_V1.3-EN.zip (9.12 MB)
VK1621S-1_V1.3-EN.pdf (3.51 MB)
VK1625_V1.3-EN.zip (2.23 MB)
RAMmapping LCD controller and driver
High cost performance LCD driver:
VK1024B  2.4V~5.2V   6seg*4com   6*3   6*2           Bias: 1/21/3   S0P-16
VK1056B  2.4V~5.2V   14seg*4com   14*3   14*2          Bias: 1/2 1/3   SOP-24/SSOP-24
VK1072B  2.4V~5.2V   18seg*4com   18*3    18*2          Bias: 1/21/3  SOP-28
VK1072C  2.4V~5.2V  18seg*4com   18*3   18*2          Bias: 1/2 1/3  SOP-28
VK1088B  2.4V~5.2V  22seg*4com   22*3                Bias: 1/21/3   QFN-32L(4MM*4MM)
VK0192   2.4V~5.2V  24seg*8com                           Bias: 1/4     LQFP-44
VK0256   2.4V~5.2V  32seg*8com                           Bias: 1/4     QFP-64
VK0256B  2.4V~5.2V  32seg*8com                          Bias: 1/4     LQFP-64
VK0256C  2.4V~5.2V  32seg*8com                           Bias: 1/4     LQFP-52
VK1621     2.4V~5.2V  32seg*4com 32*3  32*2    Bias: 1/2  1/3   LQFP44/48/SSOP48/DICE
VK1622    2.7V~5.5V   32seg*8com         Bias: 1/4     LQFP44/48/52/64/QFP64/DICE
VK1623    2.4V~5.2V   48seg*8com             Bias: 1/4      LQFP-100/QFP-100/DICE
VK1625   2.4V~5.2V  64seg*8com         Bias: 1/4       LQFP-100/QFP-100/DICE
VK1626   2.4V~5.2V  48seg*16com         Bias: 1/5       LQFP-100/QFP-100/DICE
High anti-interferenceLCD driver:
VK2C21A  2.4~5.5V 20seg*4com  16*8      Bias: 1/3  1/4   I2C bus interface      SOP-28
VK2C21B  2.4~5.5V 16seg*4com  12*8     Bias: 1/3  1/4   I2C bus interface   SOP-24
VK2C21C  2.4~5.5V 12seg*4com  8*8      Bias:1/3  1/4   I2C bus interface   SOP-20
VK2C21D  2.4~5.5V  8seg*4com 4*8     Bias: 1/3  1/4   I2C bus interface   SOP-16
VK2C22A  2.4~5.5V  44seg*4com        Bias: 1/2  1/3  I2C bus interface   LQFP-52
VK2C22B  2.4~5.5V 40seg*4com       Bias: 1/2  1/3  I2C bus interface   LQFP-48
VK2C23A  2.4~5.5V 56seg*4com 52*8     Bias:1/3  1/4   I2C bus interface   LQFP-64
VK2C23B  2.4~5.5V 36seg*8com         Bias: 1/3  1/4   I2C bus interface   LQFP-48
VK2C24    2.4~5.5V 72seg*4com68*8 60*16 Bias: 1/3  1/4  1/5  I2C bus interface LQFP-80
VK2C24B   2.4~5.5V 56seg*4com 52*8 44*16 Bias: 1/3  1/4  1/5 I2C bus interface  LQFP-64
Ultra-low power consumption LCD driver:
VKL060   2.5~5.5V  15seg*4com     Bias: 1/2  1/3     I2C bus interface    SSOP-24
VKL128   2.5~5.5V  32seg*4com     Bias: 1/2  1/3     I2C bus interface     LQFP-44
VKL144A  2.5~5.5V  36seg*4com     Bias: 1/2  1/3     I2C bus interface     TSSOP-48
VKL144B  2.5~5.5V  36seg*4com      Bias: 1/2  1/3    I2C bus interface   QFN48L (6MM*6MM)
Static display LCD  driver:
VKS118   2.4~5.2V  118seg*2com            Bias: ---           4 wire serial interface    LQFP-128
VKS232   2.4~5.2V  116seg*2com            Bias: 1/1  1/2      4 wire serial interface     LQFP-128
