1 Description The ZCC103 is adigital output temperature sensor in a four-ball wafer chip-scale package(WCSP). The ZCC103 is capable of reading temperatures to a resolution of 1°C.The ZCC103 features a two-wire interface that is compatible with both I2C andSMBus interfaces. In addition, theinterface supports multiple device access (MDA) commands that allow the masterto communicate with multiple devices on the bus simultaneously, eliminatingthe need to send individual commands to each ZCC103 on the bus. Up to eightZCC103s can be tied together in parallel and easily read by the host. TheZCC103 is especially suitable for space-constrained, power-sensitiveapplications with multiple temperature measurement zones that must bemonitored. The ZCC103 isspecified for operation over a temperature range of –40°C to 125°C 2 Features Multiple DeviceAccess (MDA): Global Read/WriteOperations I2C™ andSMBus™-Compatible Interface Resolution: 8 Bits Accuracy: ±1°CTypical (–10°C to 100°C) Low QuiescentCurrent: 3-μAActiveIQat0.25Hz 1-μA Shutdown Supply Range: 1.4V to 3.6 V Digital Output 3 Applications •Handests •Notebooks •SSDs •Servers •Telecom •Set TopBoxes •Low PowerEnvironmertal •Sensors
