The Qualcomm-Atheros IPQ6010 is the ultimate solution for high-performance wireless networking applications. With its advanced technology and powerful capabilities, the IPQ6010 delivers lightning-fast speeds, exceptional range, and unparalleled reliability. Featuring a quad-core 64-bit ARM Cortex A53 CPU, the IPQ6010 delivers industry-leading performance and power efficiency, making it ideal for a wide range of applications, from high-speed internet access and video streaming to industrial automation and IoT devices. With support for both 2.4GHz and 5GHz bands, the IPQ6010 provides exceptional coverage and throughput, ensuring that your wireless network stays connected and delivers the bandwidth you need. Thanks to its advanced security features, including WPA3 and AES encryption, the IPQ6010 provides robust protection against unauthorized access and data breaches, giving you the peace of mind you need to focus on your business. Designed with flexibility and ease of use in mind, the IPQ6010 is compatible with a wide range of networking protocols, including 802.11a/b/g/n/ac/ax, 802.3af/at/bt, and more, making it easy to integrate into your existing infrastructure. The engineers from Wallys communication have developed long-distance transmission of the router board based on the Qualcomm-Atheros IPQ6010 chipset.After testing by professional technicians, two router boards separated by six kilometers can still receive data transmitted by each other quickly and efficiently. Below are the long-distance transmission of the router boards from Wallys. DR6018 Qualcomm-Atheros IPQ6010 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Support: QUECTEL RM500Q-GL Support: QCN9074 WiFi 6E Card DR6018-S DR6018-S V02 IPQ6010/IPQ6018/IPQ6000 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 8MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate The Comparison Between The DR6018 And DR6018-S We provide superior OEM/ODM/JDM services in wireless communications and customer-specific solution.In addition to the PCBA mainboard, we can also customize indoor or outdoor antennas, which we have extensive experience in. There is also the Tooling. We can do the Tooling for the customer, to undertake a variety of materials mainly metal and plastic enclosure production. Whether antenna enclosure or router enclosure, we can customize for you. Besides of the Qualcomm chips we currently use, we can also use different chips to design according to customers' needs. MAIL:sales3@wallystech.com
