查看: 770|回复: 0
[供应] Keysight是德E5071C矢量网络分析仪
发表于 2023-2-22 18:30:31 | 显示全部楼层 |阅读模式
主要特性和功能
9 kHz 至 4.5/6.5/8.5/14/20 GHz   JIANG
2 或 4 端口,50 Ω,S 参数测试仪
提供 130 dB 宽广的动态范围、8 ms 快速测量速度和 0.005 dB/℃ 温度稳定度,可改善测量精度、提高产品良率并增加设计裕量
增强时域分析选件可对高速串行互连进行全面表征,增强您对设计的信心
所有选件均可升级,保护您的投资
选件
Additional features
E5071C-010
时域分析
E5071C-790
测量向导助手(MWA)软件
E5071C-008
频率偏置模式
E5071C-TDR
E5071C-TDR 增强型时域分析选件
Timebase stability
E5071C-UNQ
Standard  stability timebase
E5071C-1E5
High stability  timebase
Calibration documentation
E5071C-1A7
Calibration +  Uncertainties + Guardbanding (Not Accredited)
E5071C-A6J
ANSI  Z540-1-1994 Calibration
Test set
E5071C-280
2-port Test  Set, 9 kHz to 8.5 GHz without Bias Tees
E5071C-285
2-port Test  Set, 100 kHz to 8.5 GHz with Bias Tees
E5071C-480
4-port Test  Set, 9 kHz to 8.5 GHz without Bias Tees
E5071C-485
4-port Test  Set, 100 kHz to 8.5 GHz with Bias Tees
E5071C-240
2-port Test  Set, 9 kHz to 4.5 GHz without Bias Tees
E5071C-245
2-port Test  Set, 100 kHz to 4.5 GHz with Bias Tees
E5071C-440
4-port Test  Set, 9 kHz to 4.5 GHz without Bias Tees
E5071C-2K5
2-port Test  Set, 300 kHz to 20 GHz with Bias Tees
E5071C-445
4-port Test  Set, 100 kHz to 4.5 GHz with Bias Tees
E5071C-4K5
4-port Test  Set, 300 kHz to 20 GHz with Bias Tees
E5071C-4D5
4-port Test  Set, 300 kHz to 14 GHz with Bias Tees
E5071C-465
4-port Test  Set, 100 kHz to 6.5 GHz with Bias Tees
E5071C-460
4-port Test  Set, 9 kHz to 6.5 GHz without Bias Tees
E5071C-2D5
2-port Test  Set, 300 kHz to 14 GHz with Bias Tees
E5071C-265
2-port Test  Set, 100 kHz to 6.5 GHz with Bias Tees
E5071C-260
2-port Test  Set, 9 kHz to 6.5 GHz without Bias Tees
Hard disk drive options
E5071C-017
Removable Data  Storage
E5071C-019
Standard Data  Storage
Accessories
E5071C-1CM
Rack mount kit
E5071C-1CN
Front handle  kit
E5071C-1CP
Rack mount and  front handle kit
E5071C-810
Add keyboard
E5071C-820
Add mouse
谭S 135-1007-5188(微信同号)
技术咨询:蒋工135-1007-5288(微信同号)
电 话:0755-21502766 传 真:0755-21502722
客 服QQ:53540923 E5071C.jpg
