SLB628 DCDC5V升压16.8V 12V 0.5A单节锂电池升压恒压芯片
发布时间:2023-2-15 10:25    发布者:小郑
关键词: DC-DC , 电源芯片 , 升压恒压
SLB628
High Efficiency 1.2MHz
2A Step Up Converter
描述
  The SLB628 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The SLB628 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height. Internal soft-start results in small inrush current and extends battery life.
  The SLB628 features automatic shifting to pulse frequency modulation mode at light loads. The SLB628 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The SLB628 is available in a small 6-pin SOT-23 package.
特性
• Integrated 80mΩ Power MOSFET
• 2V to 24V Input Voltage
• 1.2MHz Fixed Switching Frequency
• Internal 4A Switch Current Limit
• Adjustable Output Voltage
• Internal Compensation
• Up to 28V Output Voltage
• Automatic Pulse Frequency Modulation
Mode at Light Loads
• up to 96% Efficiency
• Available in a 6-Pin SOT23-6 Package
应用领域
• Battery-Powered Equipment
• Set-Top Boxed
LCD Bais Supply
• DSL and Cable Modems and Routers
• Networking cards powered from PCI
or PCI express slots
电路图
本文地址:https://www.eechina.com/thread-810642-1-1.html     【打印本页】
