Qualcomm QCN9074 4x4 MIMO 802.11ax MX6974 F5 WIFI6 Module
发布时间:2023-2-10 14:38
发布者:maxon2023
QCN9074
![]() Description MX6974 F5 802.11ax Embedded Wireless modules that adopts M.2 E-key and supports PCI Express 3.0 protocol. It adopts Qualcomm® 802.11ax Wi-Fi technology, supports the 5180-5850GHz frequency band, has AP and STA functions with 4x4 MIMO and 4 spatial streams, suitable for applications of 5GHz IEEE802.11a/n/ac/ax. It is equipped with a dynamic frequency selection (DFS) function which has higher transmission efficiency than the previous generation. Specifications Type: Wireless Module Chip: QCN9074 IEEE Standard: IEEE 802.11ax Connector: PCI Express 3.0, M.2 E-key Working voltage: 3.3V/5V Frequency range: 5G:5.180GHz~5.850GHz Modulation technology: 802.11n:OFDM(BPSK,QPSK,16-QAM,64-QAM,256-QAM) 802.11ac:OFDM(BPSK,QPSK,16-QAM,64-QAM,256-QAM) 802.11ax:OFDMA (BPSK,QPSK,DBPSK,DQPSK,16-QAM,64-QAM, 256-QAM,1024-QAM,4096-QAM) Power (per chain): 802.11ax:Max. 21dBm Power consumption: ≦15W Receiving Sensitivity: 11ax: HE20 MCS0 <-89dBm / MCS11 <-64dBm HE40 MCS0 <-89dBm / MCS11 <-60dBm HE80 MCS0 <-86dBm / MCS11 <-58dBm Antenna Connector: 4 x U. FL Operating Environment: Temperature: -20°C to 70°C/-4 ~ 158℉; Humidity: 95% (non-condensing) Storage Environment: Temperature: -40°C to 90°C/-40 ~ 194℉; Humidity: 90% (non-condensing) Certification: RoHS/REACH Weight: 20g Dimensions (W*H*D): 60 x 57 x 4.2 mm (±0.1mm) |
