Industrial wireless AP/IPQ4019/IPQ4029 OpenWrt QSDK 2.4/5G dual bands 802.11ac
发布时间:2022-12-6 15:29    发布者:wallyswifi
关键词: pcba , qsdk , ipq4019 , openwrt
Description
DR-AP40X9-A  is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR40X9(IPQ4019/IPQ4029) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna
■  5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■  Dimension: 132x 119 x 34 mm
■  Aluminum alloy material
■  Support WallysDR40X9
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    IPQ4029/IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
    Antenna Connector
    2 x 5G MMCX connectors;2x2.4G MMCX
    10/100/1000Mbps Gigabit Ethernet
    2xRJ45
    SFP connector
    1xSFP fiber module connector (optional)
    3G/4G connector
    1xminipcie 3G/4G connector support with two sim card
    USB connector
    1xUSB 3.0 connector
    POE
    24V~48V passive POE
    DC Jack
    24V~48V power supply
    ROHS Compliance
    YES
    Dimension
    115mm x 105mm x 16mm
    Max Power
    48.1V x 0.180A= 8.658W
    Nor Flash
    2MB~32MB
    Nand Flash
    128MB
    DDR
    256MB~512MB
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11a
    6 Mbps
    27dBm
    30dbm
    ±2dB
    54 Mbps
    23dBm
    26dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    26dBm
    29dbm
    ±2dB
    MCS7, MCS15
    22dBm
    25dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    21dBm
    24dbm
    ±2dB
    802.11ac
    MCS0, MCS10,MCS20
    25dBm
    28dbm
    ±2dB
    MCS9,MCS19,MCS29
    19dBm
    22dbm
    ±2dB
    Radio RX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Sensitivity
    802.11a
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -93dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
    802.11AC HT40
    MCS0, MCS10,MCS20
    -90dBm
    MCS9,MCS19,MCS29
    -67dBm
    802.11AC HT80
    MCS0, MCS10,MCS20
    -88dBm
    MCS9,MCS19,MCS29
    -62dBm
    Radio TX Specifications(2412MHz-2482MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11g
    6 Mbps
    27dbm
    30dbm
    ±2dB
    54 Mbps
    25dbm
    28dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    26dbm
    29dbm
    ±2dB
    MCS7, MCS15
    25dbm
    28dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    26dbm
    29dbm
    ±2dB
    MCS7, MCS15
    24dbm
    27dbm
    ±2dB
    Radio RX Specifications(2412MHz-2482MHz)
    Operating Mode
    Data Rate
    Sensitivity
    802.11g
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -93dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
    Version
    Item
    Information
    DR40X9-1
    CPU is IPQ4019
    DR40X9-2
    CPU is IPQ4029
    LED & GPIO header
    Item
    Information
    Note
    1
    PWR LED
    2
    Eth1 LED
    3
    Eth2 LED
    4
    2.4G LED
    GPIO32
    5
    5G LED
    GPIO50
    6
    Strength LED
    GPIO36
    7
    Strength LED
    GPIO39
    8
    NC
    9
    GND
    10
    Uart1_TX
    GPIO8
    11
    Uart1_RX
    GPIO9
    12
    NC
    13
    NC
    14
    NC
    15
    GND
    16
    PWR
    Serial Port
    Item
    Information
    1
    PWR
    2
    Uart0 TX
    3
    Uart0 RX
    4
    GND
    GPIO
    Item
    Information
    GPIO11
    Control for the switch of SIM cards
    Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.  Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.  Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
    Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
    Skype/EMAIL/Teams:sales@wallystech.com
    WEB:https://www.wallystech.com/
本文地址:https://www.eechina.com/thread-807293-1-1.html     【打印本页】
