查看: 523|回复: 0
[供应] ZCC575A 数字温度传感器替代LM75
发表于 2022-10-28 17:59:14 | 显示全部楼层 |阅读模式
Description
The ZCC575 is a digital-type high-accurate on-chip integrated temperature sensor chip with an integrated high resolution sigma-deltaconverter and I2C/SMBus digital interface. It is register and functioncompatible with industrial standard LM75 digital temperature sensor. ZCC575 isavailable in E-MSOP8 package, it offers hardwarepin and firmware compatibility to easy upgrade from LM75xdesign.
Digital communication  2-wire  interface which operates up to 400KHz of fast mode and2.5MHz of high-speed mode. There are 3 hardware address pins, A0/A1/A2, whichcould configure the I2C address externally.         The ZCC575has a dedicated over-temperature shutdown output (OS) pin with programmablehigher or lower limit in  hysteresis.  The OS pin could also be output polarityreverse by configure POL register bit setting in configuration register. Thereis a consecutive fault measurements function which could be programmed by1/2/3/4counts. The OS pin will enabled if the temperature conversion data isover the pre-set limitation value continuously, and satisfies the FQ[1:0]resistersetting.
Features
■     Temperatureaccuracy
‐         ±1℃ from -20℃~80℃
‐         ±2℃ from -40℃~125℃
■     Lowpowerconsumption
•            4.5uA shutdown current atVDD=5.0V
•            125uA continuous conversioncurrent
■     2.2~8.0Vultra-wide operation supplyvoltage
■     High PSR intemperaturemonitoring
■     I2C &SMBusdigital communicationinterface
■     LM75 function andregistercompatible
■     0.0625℃ temperatureresolution
■     Supportup to 32 devices by A0/A1/A2 pin hardware configuration
■     OS     pin     open-drain      alert      and      interruptmulti-function
■     OS outputpolarityconfiguration
■     Embedded one-shotconversionmode
Applications
■     Home appliancethermalcontrol
■     Server boardtemperaturemonitoring
■     Thermostatcontrol
■     Environmentaltemperaturemonitoring
■     Electronicequipment andfacilities
■     General systemthermalmanagement
