查看: 545|回复: 0
[供应] 9V 12V推挽式变压器驱动器ZCC6602
发表于 2022-10-26 18:04:12 | 显示全部楼层 |阅读模式
DESCRIPTION
The ZCC6602 is amonolithic oscillator/power-driver, specifically designed for small formfactor, isolated power
supplies inisolated interface applications. It drives a low-profile, center-tappedtransformer primary from a 2.5 V
to 12V DC powersupply. The secondary can be wound to provide any isolated voltage based ontransformer
turns ratio.
The ZCC6602consists of an oscillator followed by a gate drive circuit that provides thecomplementary output
signals to drivethe ground referenced N-channel power switches. The internal logic ensuresbreak-before-make
action between thetwo switches.
The ZCC6602 isavailable in a small SOT23-5 package, and is specified for operation attemperatures from –
40°C to 125°C.
FEATURES
• Push-PullDriver for Small Transformers
• Single 2.5V To 12 V Supply
• HighPrimary-side Current Drive:
– 5 VSupply: 650 mA (max)
– 3.3 VSupply: 450 mA (max)
• Low Rippleon Rectified Output Permits Small
Output Capacitors
• Soft startand Current limit
• Thermalshutdown
• Small5-pin SOT23 Package
Short- circuit
protection
Over-temperatureprotection
•APPLICATIONS
• IsolatedInterface Power Supply for CAN, RS-
485, RS-422, RS-232,SPI, I2C, Low-Power LAN
• IndustrialAutomation
• ProcessControl
• MedicalEquipment
