查看: 521|回复: 0
[供应] 3.0A, 40V, 500kHz, Step-Down Converter ZCC2467
发表于 2022-10-19 14:04:15 | 显示全部楼层 |阅读模式
DESCRIPTION
The ZCC2467 is ahigh frequency step-down switching regulator with integrated internalhigh-side, high voltage power MOSFET. It provides 3.0A output with current modecontrol for fast loop response and easy compensation.The wide 6V to 40V inputrange accommodates a variety of step-down applications, including those inautomotive systems. A 100μA operational quiescent current allows use inbattery-powered applications. High power conversion efficiency over a wide loadrange is achieved by scaling down the switching frequency at light loadcondition to reduce the switching and gate driving losses. The frequencyfoldback prevents inductor current runaway during startup and thermal shutdownprovides reliable, fault tolerant operation. The ZCC2467 is available inthermally enhanced SOIC8 package.
FEATURES
• 100μA Quiescent Current
• Wide 6V to 40V Operating Input Range
• 150mΩ Internal Power MOSFET
• 500kHz Fixed Switching Frequency
• Ceramic Capacitor Stable
• Internal Soft-Start
• Precision Current Limit without a Current Sensing Resistor
• Up to 95% Efficiency
• Output Adjustable from 0.8V to 30V
• Available in SOIC8 with Exposed Pad Packages
APPLICATIONS
• Game Machines
• Automotive Systems
• Industrial Power Systems
• Distributed Power Systems
• Printer Systems
• Battery Powered Systems
