查看: 436|回复: 0
[供应] ZCC1001E 100V 1A降压芯片
发表于 2022-10-12 16:23:41 | 显示全部楼层 |阅读模式
Description
The ZCC1001E isa high voltage, non-synchronous step-down converter operates over a wide rangeinput voltage 9V to 100V. The ZCC1001E integrates a 120-V 400-mΩ high-sideMOSFET.
The ZCC1001Edelivers 1A continuous load current with up to 95% efficiency. The ZCC1001Eoperates with fixed frequency peak current control with built-in compensationeliminates the need for external components.Cycle-by-cycle current limit inhigh-side MOSFET protects the converter in an overload condition. Hiccup modeprotection is triggered if the over-current condition has persisted for longerthan the present time.
The ZCC1001Eexhibits protection features that protect the load from faults likeunder-voltage,over-current and over-temperature.
The ZCC1001E isavailable in an ESOP-8 package.
Features
• 9V to 100V input voltage range
 •1.5A current limit
 •1A continuous load current
• 95% Peak Efficiency
• 400μA operating quiescent current
 •120V 400-mΩ high-side MOSFET
• Peak Current mode control
• 150 kHz Fixed Frequency
 •Internal compensation for easeof use
 •Up to 92% duty cycle
• 0.8V voltage reference
• 1μA shutdown current
• 150ms Hiccup mode short circuitprotection
Function
• Thermal shutdown Function
