查看: 698|回复: 0
[供应] ZCC66099 低功耗升压芯片替代SGM66099
发表于 2022-9-27 18:02:15 | 显示全部楼层 |阅读模式
1.GENERALDESCRIPTION
The  ZCC66099 is a synchronous step-up converter with 0.65μA ultra low quiescentcurrent. It is designed for products powered by alkaline battery, NiMH rechargeablebattery, Li-Mn battery or rechargeable Li-Ion battery, for which highefficiency under light load
conditionis critical to achieve long battery life operation.
The  ZCC66099 step-up converter only consumes 0.65μAquiescent current under light load condition and can  achieve up to 75% efficiency at 10μA loadwith fixed output voltage version. It can also support up to 300mA outputcurrent from 3.3V to 5V conversion, and achieve up to 93% efficiency at 200mAload.
The  ZCC66099 also offers both down mode  andpass-throughoperation for different applications.  Indown mode, the output voltage can still be regulated at target value even wheninput voltage is higher than output voltage. In pass-through mode, the output voltagefollows input voltage. The ZCC66099 exits down mode and enters into pass-throughmode when VIN > VOUT + 0.3V.
The  ZCC66099 supports true shutdown function whenit is disabled, which disconnects the load from the input supply to reduce thecurrent consumption.
TheZCC66099  offers both adjustable outputvoltage version and fixed output voltage versions. It is available in GreenWLCSP-1.22×0.83-6B and TDFN-2×2-6AL packages.
2.FEATURES
Operating Input Voltage Range: 0.9V to 5.2V
Ultra Low Quiescent Current
0.6μA Ultra Low IQ  into VOUT Pin
0.05μA Ultra Low IQ  into VIN Pin
1.2MHz Fixed Frequency Operation
Adjustable Output Voltage from 2.5V to 5.2V
Fixed Output Voltage Versions Available
Power-Save Mode for ImprovedEfficiency at Low Output Power
Regulated Output Voltage in Down Mode
True Disconnection During Shutdown
Up to 75% Efficiency at 10μA Load with Fixed Output VoltageVersion
Up to 93% Efficiency from 10mA to300mA Load -40
Range to +85℃ Operating Ambient Temperature
Available in Green WLCSP-1.22×0.83-6B and TDFN-2×2-6ALPackages
3.APPLICATIONS
Memory LCD Bias
Optical Heart Rate Monitor LEDBias
Wearable Applications
Low Power Wireless Applications
Portable Products
Battery Powered Systems
