Wallys industrial 2x2 2.4G&5G router/QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax
发布时间:2022-9-23 13:53
发布者:wallyswifi
Wallys industrial 2x2 2.4G&5G router/QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax We developed and designed the industrial router/industrial moudle/industrial antenna. The chips are mainly Qualcomm and MTK. At the same time provide customized services ![]() Qualcomm-Atheros IPQ6010 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Support: QUECTEL RM500Q-GL Support: QCN9074 WiFi 6E Card
Parameter RatingUnitSupply Voltage 24V~48VOperating Temperature Range -40 to +70oCStorage Temperature Range -45 to +105oCOperating Humidity Range 5 to +95 (non-condensing)%Hardware SpecificationsSymbolParameterCPUQualcomm-AtherosIPQ6010 CPU FrequencyQuad-core ARM 64 bit A53 @1.8 GHz processor System Memory1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design Ethernet Port1x 1Gbps Ethernet Ports & POE3x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port NGFF SlotM.2 (NGFF) “E Key” Socket with MiniPCIe 3.0 SD Card Slot1x SD Card Slot USB /header1x USB 2.0 Port POE24V~48V passive POE/Active POE(Suport 802.3bt) DC Jack24V power supply LED headerFFC/FPC Connector Serial Port1x Serial Port 4 Pin Connector WirelessOn-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain4 x MMCX Connectors Bluetoothoptional Nor Flash8-32MB(normally is 8MB) Nand Flash256MB DDR1GB Dimension185mm x 116mmRadio TX Specifications(5180MHz-5825MHz)Operating ModeData RatePowerTolerance 1 Chain2 Chains 5Ghz 802.11ax HE20MCS020dBm23dbm MCS120dBm23dBm±2dB MCS220dBm23dBm±2dB MCS320dBm23dBm±2dB MCS419dBm22dBm±2dB MCS518dBm21dBm±2dB MCS617dBm20dBm±2dB MCS716dBm19dBm±2dB MCS815dBm18dBm±2dB MCS914dBm17dBm±2dB MCS1013dBm16dBm±2dB MCS1113dBm16dbm±2dB 5Ghz 802.11ax HE400MCS020dBm23dbm MCS120dBm23dBm±2dB MCS220dBm23dBm±2dB MCS320dBm23dBm±2dB MCS419dBm22dBm±2dB MCS518dBm21dBm±2dB MCS617dBm20dBm±2dB MCS716dBm19dBm±2dB MCS815dBm18dBm±2dB MCS914dBm17dBm±2dB MCS1013dBm16dBm±2dB MCS1113dBm16dbm±2dB 5Ghz 802.11ax HE80MCS020dBm23dbm MCS120dBm23dBm±2dB MCS220dBm23dBm±2dB MCS320dBm23dBm±2dB MCS419dBm22dBm±2dB MCS518dBm21dBm±2dB MCS617dBm20dBm±2dB MCS716dBm19dBm±2dB MCS815dBm18dBm±2dB MCS914dBm17dBm±2dB MCS1013dBm16dBm±2dB MCS1113dBm16dbm±2dB Android Emoji, EmojiSymbols">Since its inception in 2010, Wallys has had a strong team, including dozens of research and development personnel, a complete set of assembly lines, they play an irreplaceable role. Under the premise of ensuring the product quality, we will deliver the goods at the fastest speed and maximize the product benefit. We are trustworthy, trust us, choose us! Wallys provides all services from r&d, design to production and post-maintenance. There can be a buyout or an unbuyout mode. China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive. Skype/ EMAIL:sales@wallystech.com WEB: https://www.wallystech.com/ Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw |
