Wallys industrial wifi5 router/IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G
发布时间:2022-9-21 17:25    发布者:wallyswifi
APPLICATIONS
Profi WiFi hotspot coverage
Commercial radio coverage
Hotel Wireless application
Country coverage
Internet for passengers (bus, train, plane, …)
Security Surveillance
Some special scene application
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
    Antenna Connector
    2 x 5G MMCX connectors;2x2.4G MMCX
    10/100/1000Mbps Gigabit Ethernet
    2xRJ45
    SFP connector
    1xSFP fiber module connector (optional)
    3G/4G connector
    1xminipcie 3G/4G connector support with two sim card
    USB connector
    1xUSB 3.0 connector
    POE
    24V~48V passive POE
    DC Jack
    24V~48V power supply
    ROHS Compliance
    YES
    Dimension
    115mm x 105mm x 16mm
    Max Power
    48.1V x 0.180A= 8.658W
    Nor Flash
    2MB~32MB
    Nand Flash
    128MB
    DDR
    256MB~512MB
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11a
    6 Mbps
    27dBm
    30dbm
    ±2dB
    54 Mbps
    23dBm
    26dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    26dBm
    29dbm
    ±2dB
    MCS7, MCS15
    22dBm
    25dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    21dBm
    24dbm
    ±2dB
    802.11ac
    MCS0, MCS10,MCS20
    25dBm
    28dbm
    ±2dB
    MCS9,MCS19,MCS29
    19dBm
    22dbm
    ±2dB
    Radio RX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Sensitivity
    802.11a
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -93dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
    802.11AC HT40
    MCS0, MCS10,MCS20
    -90dBm
    MCS9,MCS19,MCS29
    -67dBm
    802.11AC HT80
    MCS0, MCS10,MCS20
    -88dBm
    MCS9,MCS19,MCS29
    -62dBm
Stable networks guarantee for the ongoing continuity of your video surveillance. Our boards could establish a stable connected wireless environment which is critical for a security surveillance system.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We’re a supplier to Facebook.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
本文地址:https://www.eechina.com/thread-801496-1-1.html     【打印本页】
