查看: 683|回复: 0
[供应] ZCC103数字温度传感器芯片替代TMP103
发表于 2022-9-9 15:54:57 | 显示全部楼层 |阅读模式
1 Description
The ZCC103 is adigital output temperature sensor in a four-ball wafer chip-scale package(WCSP). The ZCC103 is capable of reading temperatures to a resolution of 1°C. TheZCC103 features a two-wire interface that is compatible with both I2C and SMBusinterfaces. In
addition, theinterface supports multiple device access (MDA) commands that allow the masterto communicate with multiple devices on the bus
simultaneously,eliminating the need to send individual commands to each ZCC103 on the bus. Upto eight ZCC103s can be tied together in parallel and easily read by the host.The ZCC103 is especially suitable for space-constrained, power-sensitiveapplications with multiple temperature measurement zones that must be monitored.
The ZCC103 isspecified for operation over a temperature range of –40°C to 125°C
2 Features
Multiple DeviceAccess (MDA):
Global Read/WriteOperations
I2C™ andSMBus™-Compatible Interface Resolution: 8 Bits
Accuracy: ±1°CTypical (–10°C to 100°C)
Low QuiescentCurrent:
3-μAActiveIQat0.25Hz
1-μA Shutdown
Supply Range: 1.4V to 3.6 V
Digital Output
3 Applications
•Handests
•Notebooks
•SSDs
•Servers
•Telecom
•Set Top Boxes
•Low Power Environmertal
•Sensors
