查看: 515|回复: 0
[供应] 10073C安捷伦示波器探头
发表于 2022-8-25 20:56:35 | 显示全部楼层 |阅读模式
Agilent 10073C示波器探头
10073C安捷伦示波器探头 JIANG
Bandwidth: 500 MHzSystem risetime (calculated): <700 ps Attenuation Ratio: 10:1 Inputresistance: 2.2 MΩ (when terminated into 1 MOhm)
The Agilent 10073Cpassive probe is our most rugged 500 MHz probe. With a 10:1 attenuation ratioand high 2.2 M ohm input impedance, it is ideal as a general purpose, highbandwidth passive probe for the Agilent 300 MHz - 1 GHz 6000 series, 7000, 8000and 9000 Series oscilloscopes. The probe identification feature automaticallyconfigures the oscilloscope for the probe attenuation.
The followingaccessories are included: retractable hook tip; orange, white, blue and greenidentification tags; ground bayonet, IC probing tip, adjustment tool and analligator clip ground lead.
·        Bandwidth: 500 MHz
·        System risetime (calculated): <700 ps
·        Attenuation Ratio: 10:1
·        Input resistance: 2.2 MΩ (when terminated into 1 MOhm)
·        Input capacitance: ~12 pF
·        Maximum input (dc + peak ac): 500 V CAT I (mainsisolated) 300 V CAT II (post receptacle mains)
·        Compensation range: 6 - 15 pF谭S 135-1007-5188(微信同号)
技术咨询:蒋工135-1007-5288(微信同号)
电 话:0755-21502766 传 真:0755-21502722
客 服QQ:53540923 10073C.jpg
