查看: 853|回复: 0
[供应] ZCC6303 60V宽电压输入升压芯片,恒流驱动LED芯片 兼容SY7200
发表于 2022-8-12 16:31:13 | 显示全部楼层 |阅读模式
ZCC6303  3.0V~60V宽电压输入升压芯片,恒流驱动LED芯片
General Description
   The ZCC6303 is a constant frequency ,mode step-up converter intended forsmall ,low power applications .The ZCC6303 switches at 1.2MHz and allows theuse of tiny ,low cost capacitors and inductors 5mm or less in height. Internalsoft-start results in small inrush current and extends battery life.
   The ZCC6303 includes under-voltage lockout ,current limiting ,and thermaloverload protection to prevent damage in the event of an output overload .TheZCC6303 is available in a small 6-pin SOT-23 package.
Features
·3.0V to 60V WideInput Voltage
·Integrated 250mΩ 60V Power MOSFET
·1.2MHz FixedSwitching Frequency
·U to 95% Step-upconversion efficiency
·1mA Light load modelefficiency uo to 80%
·Low than 10uAShutdown current
·Low than 0.1mA staticcurrent
·Built-inCycle-by-cycle current limiting
·Built-in thermalshutdown protection
·Built-in under-voltage protection
·Built-in loop compensation
·Built-in soft start circuit
·Simple external
·Available in a 6-pin SOT-23 package
Applications
·DigtialSet-top Box(STB)
·TabletPersonal Computer(Pad)
·LCD Bias Supply
·Battery-PoweredEquipment
·Portable MediaPlayer(PMP)
·General Purposes
