查看: 820|回复: 0
[供应] 100V 输入同步降压最大5A输出电流 ZCC1005
发表于 2022-7-25 16:55:09 | 显示全部楼层 |阅读模式
                         100V输入同步降压最大5A输出电流 ZCC1005
Description
The ZCC1005 is a high voltage, synchronous step-downconverter operates over a wide range input voltage 9V to 100V. The ZCC1005 integratesa 100-V 400-mΩ high-side MOSFET.
The ZCC1005 delivers 1.5A continuous load currentwith up to 95% efficiency. The ZCC1005 operates with fixed frequency peakcurrent control with built-in compensation eliminates the need for externalcomponents. Cycle-by-cycle current limit in high-side MOSFET protects theconverter in an overload condition.
Hiccup mode protection is triggered if the over-currentcondition has persisted for longer than the present time.
The ZCC1005 exhibits protection featuresthat protect the load from faults like under-voltage, over-current andover-temperature.
The ZCC1005 is available in an ESOP-8package.
Features
• 9V to 100V input voltage range
• 1.5A/5A continuous output current
• 95% Peak Efficiency
 • 400μA operating quiescentcurrent
 • 100V 400-mΩ high-side MOSFET
• Peak Current mode control
• 150 kHz Fixed Frequency
• Internal compensation for ease of use
• Up to 92% duty cycle
 • 0.8V voltage reference
• 1μA shutdown current
• 3A/6A cycle-by-cycle current limit
• 150ms Hiccup mode short circuit protection
Function
• Thermal shutdown Function
• ESOP-8 package
• Applications
• Charger in vehicle
• Battery Chargers
• Power adapter
