查看: 2609|回复: 1
SLB628 高效率1.2MHz 2A升压转换器
发表于 2022-7-25 14:42:39 | 显示全部楼层 |阅读模式
关键词: DCDC , 升压转换器 , 升压恒压
描述
The SLB628 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applica
tions. The SLB628 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height. Internal soft-start results in small inrush current and extends battery life.
The SLB628 features automatic shifting to pulse frequency modulation mode at light loads. The SLB628 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The SLB628 is available in a small 6-pin SOT-23 package.
特性
• Integrated 80mΩ Power MOSFET
• 2V to 24V Input Voltage
• 1.2MHz Fixed switching Frequency
• Internal 4A Switch Current Limit
• Adjustable Output Voltage
• Internal Compensation
• Up to 28V Output Voltage
• Automatic Pulse Frequency Modulation
Mode at Light Loads
• up to 96% Efficiency
• Available in a 6-Pin SOT23-6 Package
应用
• Battery-Powered Equipment
• Set-Top Boxed
LCD Bais Supply
• DSL and Cable modems and Routers
• Networking cards powered from PCI
or PCI express slots
原理图
 楼主| 发表于 2022-7-25 14:50:11 | 显示全部楼层
欢迎围观
