查看: 1208|回复: 0
[供应] 1 x M.2 Card,QCN9074,AX200NGW,IPQ6018-wallys
发表于 2022-5-23 11:27:18 | 显示全部楼层 |阅读模式
关键词: QCN9074 , IPQ6018 , AX200NGW
Features
Support 1 pcs M.2 card
Support AX200NGW
SupportDR9074-6E
RoHS compliance ensure a high level protection of human health and the
environment from risks that can be posed by chemicals
Product Description
DR3G11 is an adapter card with one  M.2 slot. It can be used in a PC with a PCIe slot. Use this new adapter to expand your connectivity and upgrade your device to use the latest  m.2 interface cards. Each comes with both low and regular profile brackets.
Brackets include holes for mounting SMA connectors, or for using as cable exit holes.
    Specifications
    Parameter
    Rating
    Unit
    Input voltage
    12
    V
    Output Voltage
    3.3
    V
    Operating Temperature
    -40 to +70
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    ROHS Compliance
    YES
    Outline
    Parameter
    Rating
    Unit
    Length
    110
    Mm
    Width
    66
    Mm
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
