查看: 1374|回复: 0
[供应] QCN9074 802.11ax 4x4 M.2 5GHz wifi6-QCN9072/QCN9024-Wallys
发表于 2022-5-7 14:40:00 | 显示全部楼层 |阅读模式
关键词: QCN9074 , QCN9024 , QCN9072
■ Qualcomm Atheros QCN9074
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
■ Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to 70
    oC
    Storage Temperature Range
    -40 to 90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    Chipset
    WLAN Host Interface
    System Memory
    2Mbit serial I2C bus EEPROM
    Standard Operating Voltage
    5V
    Operating Systems
    QSDK
    Host Interface
    M.2 E Key
    Antenna Cable / Port
    4 x MMCX Connectors,4T4R
    Frequency Range
    5.15GHz-5.95GHz
    Data Rates for WALN
    Channel Spectrum Widths for WLAN
    Support 20/40/80/160MHz at 5GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
    Temperature Range
    Operating: -20°C to 70°C, Storage: -40°C to 90°C
    Humidity
    Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
    Certification
    TBD
    Power Consumption
    TBD
    Reference Design
    PN02.1
    Dimensions (WxHxD)
    57mm x 63mm x 6mm
    M.2 Pin Definitions
    Pin No.
    Name
    Pin No.
    Name
    1
    GND
    2
    VDD3P3_PCIE
    3
    4
    VDD3P3_PCIE
    5
    6
    PCIE_LED0
    7
    GND
    8
    GPIO46_WCI2_UART_TXD_PCIE
    9
    TP19
    10
    GPIO47_WCI2_UART_RXD_PCIE
    11
    12
    13
    14
    15
    VDD_XPA_PCIE
    16
    PCIE_LED1
    17
    VDD_XPA_PCIE
    18
    GND
    19
    VDD_XPA_PCIE
    20
    21
    VDD_XPA_PCIE
    22
    23
    VDD_XPA_PCIE
    33
    GND
    32
    35
    PCIE0_RX0_P
    34
    37
    PCIE0_RX0_N
    36
    39
    GND
    38
    MOD_BT_STS_2
    41
    PCIE0_TX0_P
    40
    MOD_WL_ACT_2
    43
    PCIE0_TX0_N
    42
    PINE_BT_ACT_2
    45
    GND
    44
    MOD_BT_STS
    47
    PCIE0_REFCLK_P
    46
    MOD_WL_ACT
    49
    PCIE0_REFCLK_N
    48
    PINE_BT_ACT
    51
    GND
    50
    53
    PCIE0_CLKREQ_3P3_N
    52
    PCIE0_PERST_3P3
    55
    PCIE0_WAKE_3P3_N
    54
    57
    GND
    56
    59
    PCIE0_RX1_P
    58
    61
    PCIE0_RX1_N
    60
    63
    GND
    62
    65
    PCIE0_TX1_P
    64
    67
    PCIE0_TX1_N
    66
    69
    GND
    68
    71
    70
    73
    72
    VDD3P3_PCIE
    75
    GND
    74
    VDD3P3_PCIE
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
    QCN9074
    QCN9074
