查看: 1161|回复: 0
[供应] IPQ4019/IPQ4029/OpenWRT-802.11ac-wallys
发表于 2022-4-25 13:07:07 | 显示全部楼层 |阅读模式
关键词: IPQ4019 , IPQ4029
IPQ4019-2T2R-Dual-Band-2-4GHz-5GHz-support-OpenWRT-802.11ac-Wave-2
Featuring withindustrial-grade IPQ4019  chipset
Integrated with 2x 2 5G high power
Radio module and 2x2 2.4G high power  Radio module
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC
RoHS compliance ensure a high level
protection of human health and the environment from risks that can be posed by
    Symbol
    Parameter
    CPU
    IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
    Antenna Connector
    2 x 5G MMCX connectors;2x2.4G MMCX
    10/100/1000Mbps
         Gigabit Ethernet
    2xRJ45
    DC Jack
    12 power supply
    ROHS Compliance
    YES
    Dimension
    65mmx35mm x 16mm
    Max Power
    12V x 0.8A= 9.6W
    Nor Flash
    32MB
    DDR
    256MB
      1) Pin41-Pin48 indicates the differential signals of network port 1, which are 0,1,2, and 3 in sequence
      2) Pin48 to Pin52, P55 to Pin58 indicates the differential signals of network port 2. The sequence is differential signals 0,1,2, and 3
      The schematic diagram of the extended circuit is as follows:
        3) Pin64-Pin69 indicates the differential signals of USB3.0 are TX, RX, and HS in sequence
          4) Pin 79,80 is a 12V input power signal and the input voltage is in the range of 11v-13v
          5) Pin32 -Pin35 indicates the serial port signal, Pin32 indicates the output 3.3V, Pin33, and Pin34 indicates the output input signal
          The schematic diagram of the extended circuit is as follows,
          Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.
          EMAIL:sales@wallystech.com
          WEB:https://www.wallystech.com/
