查看: 1440|回复: 0
[供应] IPQ5018 QCN9074 802.11ac 2x WiFi 6E Card, support BT5.1 wallys
发表于 2022-4-19 11:28:32 | 显示全部楼层 |阅读模式
关键词: ipq5018 , 802.11ac , openwrt
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Two PCIe2.0 connector can support QCN90xx production
    Parameter
    Rating
    Unit
    Supply Voltage
    12
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
      Symbol
      Parameter
      CPU
      Qualcomm-Atheros IPQ5018
      CPU Frequency
      Dual-core ARM 64 bit A53 @1.0 GHz processor
      System Memory
      512MB DDR3L 16-bit interface with 32-bit memory bus design
      Ethernet Port
      4 x 1Gbps Ethernet Ports  or 1X2.5Gbps Ethernet Port;
      1 x1Gbps Ethernet Port
      NGFF Slot
      2 X M.2 (NGFF) “E Key” Socket with MiniPCIe 2.0(For WiFi Module)
      EMMC
      4G/8G(optional)
      USB /header
      1x USB 3.0 Port
      POE
      NA
      DC Jack
      12V power supply
      LED header
      LED for power ,Wifi strength
      Serial Port
      support
      Wireless
      On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
      2x IPEX Connectors
      BluetoothBT5.1
      Nor Flash
      8MB
      Nand Flash
      128 MB
      DDR
      512MB
      Dimension
      185mm x 116mm
      Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
      EMAIL:sales@wallystech.com
      WEB:https://www.wallystech.com/
