SL3150仪表机电控制功率电源通用 可替换U3015 外围更简单
发布时间:2022-3-31 09:47    发布者:小郑
关键词: dcdc , 降压恒压 , 电源IC , 仪器仪表 , 控制器
                             SL3150 150V Non-Isolated Off-line Regulator up to 400mA Output Current
GENERAL DESCRIPtiON
   SL3150 is a Buck regulator that
provides accurate constant voltage (CV)
regulation without opto-coupler. It has an
integrated 150V MOSFET to simplify the
structure and reduce costs. These features
make it an ideal regulator for off-line low
power applications, such as home
appliances and standby power.
   SL3150 is a green -mode-operation
regulator. Both the peak current and
switching frequency decrease as the load
decreases. This feature provides excellent
efficiency at light load, and improves the
overall average efficiency. SL3150 features
various protections, including thermal
shutdown (OTP), VCC under-voltage
lockout (UVLO), overload protection (OLP),
short-circuit protection (SCP), and open
loop protection.
   SL3150 is offered in SOP7 package.
SL3150_Ver2.0.pdf (818.42 KB)
本文地址:https://www.eechina.com/thread-786580-1-1.html     【打印本页】
小郑 发表于 2022-3-31 10:25:26
提供样品及技术支持,欢迎咨询!!!(郑生198 6087 2629)
