查看: 598|回复: 0
[供应] ZCC5145   0.6A  45V  DC/DC降压IC  替代HT7463 替代SY8401
发表于 2022-3-30 14:19:57 | 显示全部楼层 |阅读模式
1 DESCRIPTION
The ZCC5145 is amonolithic, step-down, switch- mode converter with a built-in power MOSFET. Itachieves a 0.6A peak-output current over a wide input supply range with excellentload and line regulation. Current-mode operation provides a fast transientresponse and eases loop stabilization. Fault condition protections includecycle-by-cycle current limiting and thermal shutdown.
The ZCC5145requires a minimal number of readily-available external components. The ZCC5145is available in a TSOT23-6 package.
2  FEATURES
• 0.6A Peak Output Current
 •0.6Ω Internal Power MOSFET
 •Capable to Start Up with BigOutput Capacitor
 •Stable with Low-ESR CeramicOutput Capacitors
 •Up to 94% Efficiency
 •Fixed 1.2MHz Frequency
 •Cycle-by-CycleOver-Current Protection
 •Wide 4.2V-to-45V Operating InputRange
 •Output Adjustable from 4.5V to0.94xVIN
 •Available in a SOT23-6 Package
3  APPLICATIONS
• Power Meters
• Distributed Power Systems
 •Battery Chargers
 •re-Regulator for Linear Regulators
