BCT5007 FM低噪声放大器芯片
发布时间:2022-1-6 11:36    发布者:LIJINTAO123
关键词: BCT5007 , FM低噪声放大器
BCT5007 is a Low-Noise-Amplifier (LNA), without earphone or telescopic antenna, re-using GSM antenna to receive FM-radio signal. BCT5007 is characterized with low noise, high gain and high linearity. Typical noise figure is 1.2dB and power gain is 21dB. BCT5007 is powered by 2.6V~3.6V supply with typical 2.8V. EN supports 2.8V / 1.8V GPIO input. BCT5007 integrates RF radio switch inside, implementing high impedance under shut-down condition. Shut-down current is less than 0.1μA. BCT5007 is available in slim 2.2mm×2.2mm×1mm SOT363 package. The specified operating free-air temperature ranges from -40℃ to 85℃.
APPLICATIONS
Mobile phone
MID/PAD with FM
Mobile audio device
FEATURES
Without any earphone or telescopic antenna receive FM-radio signal through re-using GSM antenna
Ultra-low noise figure 1.2dB
Standard CMOS process technology
High power gain of 21dB
High linearity
EN supports 1.8V/2.8V GPIO
Supply voltage: 2.6V-3.6V
Shutdown current:<0.1uA
Slim SOT363 package
BCT5007.pdf
567.5 KB, 下载积分: 积分 -1
本文地址:https://www.eechina.com/thread-782200-1-1.html     【打印本页】
