Introspect DP/eDP接收机/发射机测试解决方案
发布时间:2021-8-30 17:44    发布者:reetest
关键词: eDP信号源 , DP信号源 , DP Generator , eDP信号发生器 , DP信号发生器
加拿大Introspect推出业界领先的能同时支持DP/eDP从物理层信号质量到协议层功能性验证测试的信号源(Pattern Generator)测试解决方案,支持4通道测试及Edp/DP V1.4 8.1Gbps data rate,支持抖动注入(Jitter Injection),Skew, 噪声注入及协议层功能性测试及协议错误注入等测试。
Key Features:
• Protocol: supports Embedded DisplayPort (eDP) up to v1.4 and Display Port (DP) up to v1.4
•  Supported Data Rates: up to 8.1 Gbps with a fully continuous range of data rates
•  Lane Count: configurable from 1 to 4 lanes per port (L0 to L3) plus auxiliary channel (AUX)
•  Analog Controls: voltage amplitude and common mode voltage, each per lane
•  Signal Impairments: jitter injection, sinusoidal voltage noise injection, per-wire timing skew
•  Pattern Generation: full video frame generation with 8 GBytes of pattern memory
本文地址:https://www.eechina.com/thread-773350-1-1.html     【打印本页】
reetest 发表于 2021-8-30 17:45:04
更多产品信息请联系:henry.liu@reetest.com, 0755-23081325
